Seat Belts Not Retracting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2010, 11:20 PM   #1 (permalink)
Clean & Simple
TLToyota's Avatar
View TLToyota's Photo Gallery
Just lately, my seat belts are not retracting all that well. I take the seat belt off and it just kinda hangs/lays there.
Is there something i can do to fix this?
Thanks
1995 Mustang Cobra
Cobra Engine Bay
Fav Pic
1981 T-Top Mustang Coupe
1993 Corollin - Daily Driver
TLToyota is offline   Reply With Quote
Old 02-10-2010, 08:08 AM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
I have to draw mine out alot, since I am pretty fuckin fat and all... then i have to partially walk it back up.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 02-10-2010, 12:15 PM   #3 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348795
View iToaster's Photo Gallery
I think the fix for this entails removing the spring and coiling it a few more times to ensure it stays tight... but I've never done this. It seems they lose some tension over the years.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is online now   Reply With Quote
Old 02-10-2010, 12:17 PM   #4 (permalink)
Gameroom cash: $201310
View ganda1f's Photo Gallery
Cleaning the seatbelts usually helps a bit for a while. But the root cause is that the belt has a lot of tiny threads sticking out from it, which make it difficult to slide through all the openings. Happens over time as the belt wears out.
ganda1f is offline   Reply With Quote
Old 02-10-2010, 12:24 PM   #5 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
I have the same problem. It's extremely annoying. I have considered purchasing a new driver side seatbelt if they are not to much
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 02-10-2010, 12:43 PM   #6 (permalink)
Certified Yo'Mama-ologist
Hook's Avatar
View Hook's Photo Gallery
My belts aren't shredded or furry but they ALMOST go all the way up and then stop. When u try to walk it in, u can tell there's no tension on it, so I'm believing the spring idea works.
Anyone wanna do a DIY write-up? lol
Hook is offline   Reply With Quote
Old 02-10-2010, 12:58 PM   #7 (permalink)
trife96's Avatar
I'm also thinking it's the tensioner. My seat belts are not frayed either. If that spring idea is doable, I might try that first. But I need to remove it to get a good look at it and see what it will involve.
Old 02-25-2010, 03:26 PM   #8 (permalink)
Drifta89's Avatar
View Drifta89's Photo Gallery
Any luck on repairing the seatbelts? I am having the same problem and was going to just replace it with one from the junkyard, but if its possible to fix the tension then I'm all ears.
07 I4 LE (fully unloaded except for free mats and cargo net!)
Personal add ons: alarm w/remote start, XLE Grill, Lip Spoiler, OEM Sport Pedals
93 SlowRolla (Speed Isn't Everything...ah who am I kidding?)
Drifta89 is offline   Reply With Quote
Old 02-25-2010, 03:44 PM   #9 (permalink)
View stanmalu's Photo Gallery
I have that problem as well and im all ears as well, and somtimes on the passenger side the seat belt will not come out, no matter how much u pull on it. I would have to turn the car off before i can get it out, even then it dosnt come out all the time.
stanmalu is offline   Reply With Quote
Old 02-27-2010, 01:19 PM   #10 (permalink)
View Redline322's Photo Gallery
Resetting the spring does help, but if you find your seatbelt is sticking as well, the best thing to do is use armor all obn the seatbelt since it wont stain clothes either and it will free any dust/dirt causing problems with the spring and gear. It'll take a few applications to get it working the way it should again, but it does come around.
Redline322 is offline   Reply With Quote
Old 02-27-2010, 01:27 PM   #11 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
cleaning them and then giving them a light spray with some thin silicone lube spray works great also.
Old 03-07-2010, 10:51 PM   #12 (permalink)
KenLayton's Avatar
View KenLayton's Photo Gallery
I was having the same problem with my seat belt too. I tried the Armor All treatment and it worked very well indeed! I sprayed (saturated is more like it) some Armor All onto a folded paper towel and wiped it on both sides of the seat belt. Did that twice and then one more time I did just the outside edges of the belt.
Worked like a charm and I'm very happy.
KenLayton is offline   Reply With Quote
