1.6l upshift problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2010, 07:10 PM   #1 (permalink)
View Louge's Photo Gallery
Our 97 1.6l with 152K miles developed a shift problem today. I sucessfully rocked it to get it unstuck from the snow but now it won't upshift under I completely drop the throttle.
This is my first post here, a testimonial to the reliability of the car. My only repair to date has been an EGR valve quickly diagnosed with a OBDII reader.
Thanks in advance for your help.
Lou
Louge is offline   Reply With Quote
Old 02-17-2010, 07:15 PM   #2 (permalink)
BoyYota's Avatar
Gameroom cash: $138400
View BoyYota's Photo Gallery
And this is why we moved out of Maryland.
Did you jack it up and look underneath for any possible damage to the transmission?
94 Prizm LSi 1.8. Auto and still quick as hell.
BoyYota is offline   Reply With Quote
Old 02-17-2010, 07:19 PM   #3 (permalink)
No, it just happened an hour ago. I'll jack it up tomorrow.
Old 02-17-2010, 07:23 PM   #4 (permalink)
BoyYota's Avatar
Who knows, with some luck it could be a weird temporary issue and be gone by tomorrow.
Something I forgot to ask is does it not shift past 1st? Then you drop the throttle and it shifts, and you have to do this for every time you want it to go to the next gear?
Old 02-17-2010, 08:18 PM   #5 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
That sounds like muffed clutch discs....
Check the fluid for color. It should be red. You may need to drop the pan to check for metallic shavings.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 02-17-2010, 10:55 PM   #6 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
Explain this shift problem more...is it slipping or just won't shift??? You prolly wiped out the friction material in #1 clutch pack is my first assumption
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 02-18-2010, 08:50 AM   #7 (permalink)
It exhibits no slippage just won't upshift unless I completely drop the throttle. Downshifting on the brakes wasn't a problem. I didn't try it but am pretty sure it won't downshift under hard throttle.
