DRL/High Beam Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-18-2010, 02:01 PM   #1 (permalink)
View Redline322's Photo Gallery
Hey guys, I've got a 94 rolla and I cant get the DRL or high beams to work. I've checked the fuse boxes, swapped the front DRL relay and tried 2 other sets of relays above the glove box and still nothing. When I use the switch for high beams, I can hear the relay up front click but nothing out of the glove box ones and the dash light for highs doesnt light up. I was wondering if anybody had any suggestions before I went through the hassle of swapping out the multiswitch set and going through testing every wire.
Redline322 is offline   Reply With Quote
Old 02-18-2010, 05:52 PM   #2 (permalink)
DOHC VTEC
View Nusdogg's Photo Gallery
You did the check the bulbs? if not, check the switch to see if there's power going to it by using a digital multi-meter.
204whp/157wtq
Nusdogg is offline   Reply With Quote
