headliner glue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2010, 05:07 PM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
headliner glue
i finally decided to rip down my headliner, sick of it sagging and looking like crap lol, (all smoky from the previous owner so it was yellow) so i took it out today & took all the material off. do i keep the stuff on thats under the cloth or do i have to scrape all that off?
i was wondering what should i use to make my new fabric stick onto the headliner, where could i buy it?
im guessing its some type of spray adhesive glue, would walmart have something like that? what would it be called
thanks! will post pics when its all done.
Derek
dJcHiKo is offline   Reply With Quote
Old 02-23-2010, 05:31 PM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
Hmm, it typically comes off in one piece leaving bare metal, I'm guessing that you removed the fabric from that. There is a product that comes in a spray can designed for headliner fabric adhesion, I found it in Autozone... I don't know about Walmart, but I'd assume they would have it in the automotive section somewhere. Just look for something like "headliner spray adhesive." It's usually pretty powerful stuff, so use it sparingly and be careful not to get it on yourself.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 02-23-2010, 06:44 PM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Definitely scrape the remnants of the old gunk off, sandpaper should get most of it off, or use a stiff brush (just be careful not to push too hard). As for reattaching the head-liner, make sure you're in a very warm place when you do it, this will allow the glue/adhesive to set properly, without the risk of sagging. Might pay to wait for a warm sunny day, preferably when the interior is hot from sitting in the sun.
You can use a foam type adhesive to secure the head-liner or use 3M spray-on adhesive (like iToaster mentioned). I think it's called 'Super Trim Adhesive', that stuff works wonders. Be sure to use something flat to stick the head-liner down with (sort of like applying a sticker to a windscreen). Alternatively just use your hand, with your fingers tightly closed together.
Just remember to take your time as there's a good chance it will turn out full of bubbles and look like crap if you rush the job. I'll keep an eye out for the pictures when it's all done. Good luck! .
Old 02-23-2010, 10:25 PM   #4 (permalink)
dJcHiKo
dJcHiKo's Avatar
so i have to scrape off the foamy material under the cloth material? how would i get that foamy feeling back to the headliner?
thanks guys, ill try walmart and see what they got, if not ill look around some auto places
post pics asap
I believe i found some!
http://www.walmart.ca/Canada-Hardwar...=1681&tabId=21
hopefully theyll sell it to me, (im still under 18) in canada theres a law about buying aresols and spraypaint grrr
Derek
Old 02-23-2010, 11:06 PM   #5 (permalink)
Full Throttle
post pics asap
If you're going to all the trouble of taking the head-liner off then you may as well just replace the foam with new stuff . It's fairly cheap to buy and will leave it looking/feeling just like new. You could try and salvage your old foam, but it may rip and/or come apart when you try to separate it from the fabric.
I've never used the Loctite adhesive that you linked to, but it should do a good enough job. If you can spear a few more dollars then definitely invest in the 3M branded adhesive.
Old 02-24-2010, 04:24 AM   #6 (permalink)
View NDR008's Photo Gallery
I would like to see some photos of the side trims and what's keeping them stuck to the a pillar and roof edges.
Cheers.
You shouldn’t drive for the thrill, but for the pleasure of tasting the control…
NDR008 is offline   Reply With Quote
Old 02-24-2010, 07:56 AM   #7 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
If you fail to find the can marked trim adhesive I'll recommend 3-M SUper 77 spray adhesive. A bit expensive but one of the best spray adhesives out there.
-SP
Old 02-24-2010, 01:39 PM   #8 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
Cheers.
Are you talking about the plastic things on the interior? They just pop out. The ones on the roof are held in by metal clips they slide into, and the plastic on the pillars are just held on by plastic fasteners that pop out. Just be careful not to break them.
cipher93 is offline   Reply With Quote
Old 02-24-2010, 01:49 PM   #9 (permalink)
Andele, andele!
speedy25's Avatar
I second that! They are metal clips on plastic nubs. The nubs break off a little too easily. Unfortunately you dont know where they are until you get it loose or break one off. Just work the pieces off carefully.
-SP
Old 02-24-2010, 04:53 PM   #10 (permalink)
dJcHiKo
dJcHiKo's Avatar
yea i broke one clip off on each of the front pillars,
also i snapped the thing where the seatbelt is,
does anyone know how to get that peice off carefully? how do i take the seat belt off that top area to remove that panel?
(its fine that i broke it i just gotta run to the junk yard but i wanna know for the future lol
Derek
Old 02-24-2010, 05:14 PM   #11 (permalink)
View vmax84's Photo Gallery
You'd think there would be a detailed instruction process somewhere on how to remove the headliner. :-)
vmax84
vmax84 is offline   Reply With Quote
Old 02-24-2010, 08:48 PM   #12 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
Well, I removed mine to paint it blue, and it was really easy. The rear view mirror has some bolts after you pop off the cover. The roof handles unbolt after you pop some covers off. The visors unscrew. The plastic pieces all pop off easily. The ceiling lights unbolt after you remove the lens.
gold94corolla is offline   Reply With Quote
Old 02-25-2010, 12:32 AM   #13 (permalink)
Easy............uh huh, I'll be thinking of this when I get into mine!!!!! Mine is sagging as well, and will be getting into it when the weather warms up a bit.
vmax84
Old 02-25-2010, 12:39 AM   #14 (permalink)
View mr_kabo's Photo Gallery
I will wait for the pics. Good luck man.
Be simple and give your best...That's it...
mr_kabo is offline   Reply With Quote
Old 02-25-2010, 08:21 PM   #15 (permalink)
dJcHiKo
dJcHiKo's Avatar
how do u take the part off where the seat belt attaches to by the headliner?
Derek
