HELP! Light Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2010, 08:20 PM   #1 (permalink)
View pkcsampoon's Photo Gallery
Can someone show me how to replace the light bulbs for the headlights and tail lights?
pkcsampoon is offline   Reply With Quote
Old 02-28-2010, 10:19 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Seek and you shall find .
Headlight bulb removal:
http://www.toyotanation.com/forum/t296986.html
Tail light bulb removal:
http://www.toyotanation.com/forum/t300488.html
They're both incredibly easy jobs, just be sure to purchase the right bulbs, and never touch the headlight bulbs with your bare fingers.
Old 03-01-2010, 12:39 AM   #3 (permalink)
View gameguru1360's Photo Gallery
to get to the tail lights, there are 2 10mm bolts on the outside after you've raised the trunk lid and 1 10mm bolt on the inside towards the corners of the trunk. Once you've removed those 10mm bolts, you can slide the entire rear tail light assembly towards you. You don't need to disconnect the tail light wire in order to change the bulbs. You would have to disconnect the harness if you wanted to change the factory tail lights to altezza tail lights from ebay.
these are my altezza tail lights:
the brake and stop lights use the 1157 bulbs while the rear turn signal and backup lights use the 1156 bulbs.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
