Here is a list of all the available DIY threads available for the 7th gen Corolla.
If you have any new contributions or I managed to somehow miss a thread, then please PM me with the link and name and I will add it to the list right away.
Brakes, Clutch, Steering & Suspension Maintenance & Repair:
ABS Diagnostics
ABS fault
Corolla Clutch and Master Cylinder Repair
DIY: Corolla Clutch Master and Slave Cylinder Repair
DIY Ball Joint Replacement Corolla 93 - 97
DIY Brake Master Cylinder Corolla 93 - 97
DIY Front Brake Caliper Replacement Corolla 93 - 97
DIY Front End brake Pads Corolla 93 - 97
DIY Front Wheel Bearing Corolla 93 - 97
DIY Power Brake Booster Corolla 93 - 97
DIY Rear Brakes & Wheel Cylinder Corolla 93 - 02
How to install rear Koni inserts, tips
Brakes, Steering & Suspension Modifications:
[DIY] Making Your Own Front Strut Bar
http://www.toyotanation.com/forum/sh....php?p=3239284
Suspension work DIY thread.
TRD strut bar DIY
TRD strut bar DIY
Engine Maintenance & Repair:
DIY ~ 7th Gen 4afe/7afe Upper Intake Manifold Cleaning
DIY Coolant Flush & Maintenance Corolla 93 - 97
DIY Intake Manifold Interior Cleaning
DIY Rear Engine Mount
DIY Timing belt and water pump replacement Corolla 93-97
Engine Modifications:
AE101/102 20V Blacktop swap info
DIY Cooling Radiator Cooling Plate Corolla 93 - 97
DIY engine accents
DIY engine accents
DIY - How to forge and build a turbo 4a/7a motor
DIY - How to forged and build a turbo 4a/7a motor
DIY - How to make a custom CAI (cold air intake)
Kiwi-Corolla's CAI DIY on a USDM 7th Gen (56k tour France by bicycle)
DIY Installing Header 7AFE Corolla 93 - 97
DIY Painting Valve Cover Corolla 93 - 97
DIY: Polyurethane Filler in the Motor Mounts
DIY Oil Catch Can Install Corolla 93 - 97
DIY Oil Catch Can Installment Corolla 93 - 97
Exterior Maintenance & Repair:
DIY: How to clean faded yellow headlights
yellow headlights?
DIY: Painting your window frames
DIY Rear Corner Vent Glass Window Replacement Corolla 93 - 97
Exterior Modifications:
7th Gen Corolla Power Mirror DIY
AE10x JDM Front End Conversions:
AE101 JDM Conversions (Front and Rear)
DIY - 194 bulb in JDM Corner lamps
DIY - 194 bulb in JDM Corner lamps - (gen7 93-97)
DIY Front Bumper Fog Lights with HID's Corolla 93 - 97
DIY: How To Apply Vinyl To JDM Fog Light
DIY: How To Apply Vinyl To JDM Sidelights
JDM H4 Headlight Conversion Wiring Diagram 9005/9006 --> 9003
93-97 AE102 JDM H4 Headlight Wiring Diagram:
Projector headlights installation DIY
Ebay 'projector' headlights: The Installation Writeup (56K make a sammich)
Interior Maintenance & Repair:
Changing the automatic shift indicator light bulb:
any detail to change shift indicator light bulb?
DIY: A/C Odor Cleaning
DIY: How to remove the front seats
DIY Replacement Door Handles Inside & Out Corolla 93 - 97
DIY Trunk Light Switch Replacement Corolla 93 - 97
DIY Trunk Release Lever Installation
DIY Trunk release lever instalation
Interior Modifications:
DIY: Auto-Up Driver's Power Window
DIY Dashboard Cup Holder and Storage Corolla 93 - 97
DIY Drivers front lower vent install
DIY Front Power Locks Conversion Corolla 93 - 97
DIY Power Locks Conversion Corolla 93 - 97
DIY: Sparco Harness bar & UltraRacing Rear Bar install
DIY Trunk Light Install
DIY write-up for instrument gauge cluster - for the 8th gen Corolla, but the procedure is the exact same.
Installing aftermarket front door speakers
94 corolla door speakers
Miscellaneous:
Corolla Optional Extras & OEM Features
DIY: How to make a JDM drifter style key
DIY: Stebel Nautilus Truck Horn & Relay wiring
Great site for original catalogues/pictures (JDM Goodies)
Wheels & Tires
Will these rims fit?
Will these rims fit
