Trouble replacing axle seals
Hey all, been awhile since I've been on here.
Today I began what is going to be loads of work on my wife's 96 Corolla that is LONG overdue. 2 weeks ago I replaced the front brakes, and today I replaced both CV axles, axle seals, and replaced the A/T filter, pan gasket, and A/T fluid. I have loads more work planned for the coming weeks.
I purchased GS-P brand new axles from Advance Auto Parts, and Moog left and right CV axle seals. I got the left seal in after having to purchase a 1-5/8" 3/4" drive socket and a 1/2-3/4 adapter so I could use my 1/2" extension on it. I could not find a seal driver set at AutoZone near my house, and didn't want to drive all over town trying to find one.
So then I tried to get the right side axle seal in (outside diameter nearly identical to the O.D. of the 1-5/8" socket). I found it totally impossible to get that seal installed after trying for about an hour. I compared it to the original seal I removed, and the new one appeared to be about 1/32" to 1/16" larger in diameter than the original. The original one didn't look too bad and I don't think it was actually leaking beforehand, so I just put the old one back in, which went right back in quite easily.
The new seal looked pretty much the same as the old one, aside from the slight O.D. difference. I thought Moog products were pretty good quality. Maybe this one was just defective? Would I have better luck with an OEM Toyota axle seal?
