more glow gauge questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2010, 05:18 PM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
kk guys heres my problem, my glow gauges currently have a dimmer switch but i dont want that i want a simple on off switch, so i went out and bought an on off switch.
how would i wire the switch?
and how would i wire my gauges into my car?
i bought some extra feet of wire too. also i have some wires with fuses
heres a little picture i drew up to kind of help show what i mean,
help me out!
thanks
Derek
dJcHiKo is offline   Reply With Quote
Old 03-11-2010, 05:27 PM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
we not just jump them into the stock dimmer with the car...?
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 03-11-2010, 07:29 PM   #3 (permalink)
dJcHiKo
dJcHiKo's Avatar
i spliced the power and ground wires (the ones alone)you see in the diagram to the power and ground behind the stock dimmer switch, but it wont let me turn the glow gauges dimmer all the way up while the stock dimmer is turned all the way up for some reason, or else the gauges shut off.
Derek
Old 03-11-2010, 08:36 PM   #4 (permalink)
Sine Deviance's Avatar
View Sine Deviance's Photo Gallery
Put your on/off switch in the circuit between the control module and the gauges. It should go in the 12v positive (+) to the gauges from the control module.
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline   Reply With Quote
Old 03-12-2010, 08:59 AM   #5 (permalink)
dJcHiKo
dJcHiKo's Avatar
that doesnt really help, what do i run to the ACC, where do i connect the other 2 positive wires & grounds..
Need more info, perferably someone whos done this before
Derek
Old 03-12-2010, 07:51 PM   #6 (permalink)
dJcHiKo
dJcHiKo's Avatar
anyone?
Derek
Old 03-12-2010, 08:12 PM   #7 (permalink)
I explained it pretty simply. If you can't understand what a 12v constant (+) is then you need to have someone else do this for you or consult an automotive electrician's manual. The positives (+) will be your 12v constant, it needs to be run from the positive terminal on the battery so that it is always getting juice even when the key is off. Don't forget the in-line fuse. This is so your gauges can keep their 'memory' if they have custom settings, and also to keep them from pulling too much amperage from the factory wiring harness.
The ACC wire is supposed to go into the 'ACC/Accessory' fuse slot in your fuseblock, it will only get juice when the key is switched to the ACC position or the car is running. This is what tells your gauges to actually 'turn on' and start gauging things For 7th-gen Corollas there isn't one, but the Cig/Radio slot works just as well (just be careful about how many extra devices you run through it, you don't want to pull too much more amperage.) The fuseblock in question is under the dash on the driver's side in the left kick panel (the one closest to the driver's side door.) There is a little square cover with a pin you pull out to get to it.
The other positive(s) you mentioned (control wires) are probably for lighting. Consult the wiring diagram that SHOULD have come with your gauges to figure this one out.
The grounds, you can run to any bolts you can find that screw into the floorpan, firewall, or frame. There should be good spots to use behind the center dash console (where the cig lighter and ashtray are) and underneath the floor console. You can run all of the grounds to the same bolt too, if you want. Just make sure the bolt you select is actually a good ground. You can confirm with a voltmeter.
Old 03-12-2010, 08:51 PM   #8 (permalink)
dJcHiKo
dJcHiKo's Avatar
i have a wire with a fuse box on it, what size fuse do u suggest i use?
5 amp good enough?
Derek
Old 03-12-2010, 09:19 PM   #9 (permalink)
5 amp good enough?
Consult the wiring diagram that came with your gauges, the recommended fuse rating/amp draw will be on there.
Old 03-12-2010, 11:03 PM   #10 (permalink)
dJcHiKo
dJcHiKo's Avatar
no instructions what so ever and the fuse wire didnt come with the kit, i bought it seperate
Derek
Old 03-13-2010, 01:22 AM   #11 (permalink)
Ah... well, try looking up the model/part number of the glow gauges online? See if you can figure out the amp draw. If it draws 7 amps, use a 10 amp fuse, and so on. You really need to know the amp draw to know which fuse to use.
