Longer oil filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2010, 06:13 PM   #1 (permalink)
corolla96's Avatar
View corolla96's Photo Gallery
Longer oil filter
Fram PH4386 is longer than PH4967 and it's $1 cheaper at Walmart (Richmond Hill, Ontario)
If you don't like to use Fram, you can search for other brands here http://www.framcatalog.com/
http://www.framcatalog.com/PartDetai...?b=F&pn=PH4386
I am using the PH4386 right now, it fits perfectly(not touching anything).
K&N SRI, TRD FSB, Magnum Steel Braided Brake Hoses, Depo Black Housing Headlights Set, Clear Signal Lenses, 9006 6000K HID, LED corner lights, lic. plate lights, trunk lights, Ractive Sport Pedals, 20% tint front, 5% tint rear, Freeway TCD-0361-1 Deck, custom front grille
corolla96 is offline   Reply With Quote
Old 03-11-2010, 06:34 PM   #2 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
If it's longer but the same diameter, that means the oil filter volume is larger, which means lower oil pressure.
PatrickGSR94 is offline   Reply With Quote
Old 03-11-2010, 08:20 PM   #3 (permalink)
Sine Deviance's Avatar
View Sine Deviance's Photo Gallery
Not necessarily. It makes your oil capacity go up as well as filtering more oil in the same amount of time. Us Jeep guys run larger filters when off-roading, it helps clean the dirt and grit out of the oil faster. Our pressures never changed from running larger filters.
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline   Reply With Quote
Old 03-12-2010, 07:46 AM   #4 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Common mistake.
The pump will still make the same pressure, its just that the filter will hold more oil and there is more filtering media to clean the oil.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
