hood wont lock, - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-12-2010, 12:19 PM   #1 (permalink)
dJcHiKo
dJcHiKo's Avatar
View dJcHiKo's Photo Gallery
hood wont lock,
my hood will not lock, it wont go all the way down, it goes to the position where u have to open it with your hand by the grille but wont close, so anyone can get under my hood!
how do i fix this!? whys it doing that
Derek
dJcHiKo is offline   Reply With Quote
Old 03-12-2010, 01:57 PM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
stuck wire/cable
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 03-12-2010, 07:02 PM   #3 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
Spray it with WD40, they can get rusty sometimes and not close. But if that doesn't fix it, you might have had a spring pop off inside the latch.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 03-12-2010, 07:47 PM   #4 (permalink)
dJcHiKo
dJcHiKo's Avatar
Originally Posted by TI-CAVA View Post
stuck wire/cable
yea im thinking that, the popper inside the car is sticking out,
how do i fix that?
the spring looks fine from what ican see, i dont know if theres more
Derek
Old 03-12-2010, 09:29 PM   #5 (permalink)
97CorollaDX
View justtaint's Photo Gallery
I had a similar problem ((but since your the popper is sticking out, maybe not). I don't know what they're called but the black rubber bumpers that keep the hood from slamming down into the body were raised too far to allow my hood to close. I never even knew what they were for. They're threaded, screw both of them back in a little bit and see if it helps.
justtaint is offline   Reply With Quote
Old 03-12-2010, 10:26 PM   #6 (permalink)
TI-CAVA's Avatar
guide the wire back slowly then allow it to stick out itself or stay in, if it stays in try to close the hood, if it pops out again then somethings bad -spring- on the locking mechanism, try some oil on the wire and on the lock, WD-40 will dry out and do nothing but attract dust, use high quality oil, like the one for sewing machines
Old 03-12-2010, 11:03 PM   #7 (permalink)
dJcHiKo
dJcHiKo's Avatar
hopefully thats all it is ill check in a sec
ill take a look tomorrow
Derek
Old 03-13-2010, 01:07 PM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
The usual problem is the cam that locks and unlocks the latch is rusted to its pivot. Work some penetrant into the pivot and move it around until it gets free. Follow up with some grease to keep it lubed. When it gets freed you'll find the inside cable has been pulled back too.
-SP
