Air filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2010, 10:21 PM   #1 (permalink)
View pkcsampoon's Photo Gallery
Air filter
Where are the engine air filter and cabin air filter located in my 1996 Corolla??
pkcsampoon is offline   Reply With Quote
Old 03-13-2010, 10:28 PM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
there's no cabin air filter in our corollas, but the engine air filter is in the engine bay, driver's side big black box near the battery
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 03-13-2010, 10:28 PM   #3 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633350
Cabin air filters are only used in the 2003 and later models (9th Generation). As for the engine air filter, your owners manual should show the location. If you don't have the owners manual then a search of this forum should most likely turn up that information. A member could also respond with a photo...you never know....
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 03-13-2010, 10:53 PM   #4 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
As TI-CAVA mentioned, the engine's air filter is in the engine bay. It's inside the black plastic box. To get to it, all you have to do is remove the hose and pop up the clips on each side.
I managed to find a photo of my engine bay when it was stock to show you where it is:
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
TrailDust (03-13-2010)
Old 03-14-2010, 03:02 AM   #5 (permalink)
ok.
so i think i should buy a filte r like this one
http://cgi.ebay.com/ebaymotors/1993-...item5d2672491e
but how about this?
http://cgi.ebay.com/ebaymotors/93-94...item335b066cf8
Old 03-14-2010, 03:22 AM   #6 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000564
View humanoid's Photo Gallery
Choose the 1st one, it's direct drop-in. The 2nd link you provided is a so-called "cold air intake". In fact it is a hot air intake and the filter draws air from inside the engine compartment where the air is hot, while the OEM box draws air from outside the car which is much cooler.
humanoid is offline   Reply With Quote
Old 03-14-2010, 03:55 AM   #7 (permalink)
Full Throttle
Personally I'd go for the first one (the panel filter). K&N actually make aftermarket panel filters that drop straight in place of the factory one. As humanoid said, the second one (pod filter) will draw in all of the hot engine bay heat. I was running a pod filter set-up like that for months and it was sucking in far too much heat. The only time that it's worth going for a pod filter is if you make a cold air intake by placing the pod filter outside of the engine bay (under the car for example).
When I installed my CAI it made a noticeable difference compared to the short ram intake that sits in the engine bay (due to getting cold air instead of hot engine heat). Here's some shots of my old set-up, and some of the new set-up, just to give you some ideas:
OLD SET-UP:
NEW SET-UP:
Old 03-14-2010, 01:04 PM   #8 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
heres another CAI example but it requires shifthing the battery a bit and using a custom battery strap.
topnotch is offline   Reply With Quote
Old 03-14-2010, 05:12 PM   #9 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
just get the K&N drop in filter if you don't want to custom stuff... =D
1994 Corolla
GTChink is offline   Reply With Quote
Old 03-15-2010, 12:25 AM   #10 (permalink)
Sine Deviance's Avatar
View Sine Deviance's Photo Gallery
What he said. But also consider that building your own cold-air intake can often be much cheaper than buying one off the shelf. I built a 24" short-ram intake for my '95 Jeep Wrangler for around $60, including the cost of a good filter, and also brass fittings for the PCV and charcoal canister hoses. I estimate that it would have cost about $25 more to extend it and build a true CAI. That's still under $100 for a real CAI, and your average K&N short-ram intake/fake CAI system will cost over $150.
What you'll need:
-3" aluminum piping
-3" rubber extension sleeves/elbows
-A throttle body rubber seating ring kit
-A power drill with a drillbit set
-Some 3" hose clamps
-Brass fittings to fit your PCV/coal canister hoses
You can buy most of this stuff at Lowes or Home Depot. The hose clamps and the TB seating rings come from your local Auto Zone. You'll need to design your intake and measure the relevant areas in your engine bay first so you know how long the sections of pipe need to be and what angle elbows you need to buy.
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline   Reply With Quote
Old 03-15-2010, 09:24 AM   #11 (permalink)
View gameguru1360's Photo Gallery
if you live in california like I do, you'd want to go with a drop-in filter, not a long or short CAI. I haven't been able to find a CARB approved CAI.
Actually the K&N filter for our rollas doesn't really fit
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 03-15-2010, 02:42 PM   #12 (permalink)
on full afterburner
Gameroom cash: $1345097
Dunno if the newer ones are any different, but mine fits perfectly.
Old 03-15-2010, 03:05 PM   #13 (permalink)
GTChink's Avatar
yeah my K&N drop in filter fits great too ?
1994 Corolla
Old 03-17-2010, 11:58 AM   #14 (permalink)
View stanmalu's Photo Gallery
I wanted to try k&n but it is way to expensive for tat price, i jus buy fram filters.
stanmalu is offline   Reply With Quote
Old 03-17-2010, 12:59 PM   #15 (permalink)
on full afterburner
If you factor in the factor in the fact that it's washable and reusable, it will easily pay for itself in a few years.
Much cheaper in the long run.
