Third stop light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2010, 10:27 PM   #1 (permalink)
View pkcsampoon's Photo Gallery
Third stop light
Anyone knows how to get access to the third stop light?
pkcsampoon is offline   Reply With Quote
Old 03-16-2010, 10:30 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
two little clips, push the centers in and then pull them out. the plastic cover comes off and you can get at it then.
Old 03-17-2010, 07:17 PM   #3 (permalink)
sweet, thanks man.
but do u know the model of the bulb?
or i can just ask the guy in kragen? and they will find out for me?
Old 03-17-2010, 08:37 PM   #4 (permalink)
Bitter's Avatar
i think its a 921?
Old 03-17-2010, 08:44 PM   #5 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
It says in the owner's manual and should have either the number or wattage on the bulb itself.
cipher93 is offline   Reply With Quote
Old 03-18-2010, 01:41 PM   #6 (permalink)
View Will91's Photo Gallery
Good for you for keeping an eye on your light bulbs. Those brake lights are important.
One of my license plate bulbs just went out and I changed it. Toyota didn't leve me much extra wire on the socket connection so if was quite hard to pull it out far enough to get your fingers in there to insert the new bulb.
Will91 is offline   Reply With Quote
Old 03-18-2010, 06:42 PM   #7 (permalink)
View gameguru1360's Photo Gallery
the license plate lights are 921's I believe as well. It would take some work to twist out the bulb socket from the 3rd brake light but you can unscrew it without taking out the whole assembly which requires you to remove the 2 10mm bolts.
I'm wondering how much brighter high powered LED 921 bulbs would be. Right now I switched out the burned out factory bulbs for PIAA bulbs.
Totaled 1996 Corolla DX
2009 Nissan Altima 2.5S with Takeda SRI, stock dual exhausts, mesh grille
LED bulbs for dome/map/turn signal/tail light/3rd brake light/back up bulbs
gameguru1360 is offline   Reply With Quote
Old 03-18-2010, 07:15 PM   #8 (permalink)
The problem I've heard of with some LEDs, especially in brake lights, is they can actually look dimmer in a housing that isn't designed to project/direct the light off of them. That area though in the third light is possibly small enough it will work.
While we're on this topic, has anyone tried a LED in the area that lights the AC/fan controls? I've been considering a blue one but can't remember offhand what the number of the bulb is (I THINK it's a five watt though). Would love for something to match the ones I just put in my gauge cluster...
Old 03-18-2010, 09:40 PM   #9 (permalink)
they might be 174
I've put a 9 LED bulb for the dome light which looks similar to the console lighting in the xD, xB and TC
Old 03-19-2010, 02:43 AM   #10 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
I've got an LED high stop lamp (third stop light) and it emits the light perfectly. It's an aftermarket one however, not sure how much light a standard one would emit if you modified it to use LEDs. Gold94corolla did that once.
I uploaded some pics on this page:
http://www.toyotanation.com/forum/sh...ED#post3093039
Old 03-21-2010, 01:49 AM   #11 (permalink)
I've seen regular LED and high power LED bulbs. The high power LEDs use 7w whereas the regular LED's are usually 2 or 3w. But the ones to get are the LED bulbs that have the light emitting on the sides not just the tip.
Like these LED bulbs:
http://www.v-leds.com/921-LED/Red-LE...orLanding/true
