Transmission is acting up, any advice? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-17-2010, 12:42 PM   #1 (permalink)
Yota4life
View CBR_15's Photo Gallery
I have a '93 corolla with a 3psd auto transmission o/d. The car will work in reverse, but won't work in D 2 or L. Did a transmission fluid change, and nothing. When the car warms up(after 15mins or longer), it'll move SLOWLY in D, 2, or L. Is it time for a new transmission? Speedsensor? Neutral switch? Let me know, because I need a car bad!
CBR_15 is offline   Reply With Quote
Old 03-17-2010, 01:09 PM   #2 (permalink)
Sine Deviance's Avatar
View Sine Deviance's Photo Gallery
Hmm... a couple possibilities...
1. The transmission control module. If this was faulty it could easily cause your problem. I think the TCM is on the main ECU.
2. Transmission bands/clutch packs worn. Time for a transmission rebuild.
I'm betting on #2, because if the TCM is on the ECU and it was causing the problem, chances are the ECU itself would be damaged and the car wouldn't run or wouldn't run properly.
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline   Reply With Quote
Old 03-18-2010, 12:04 AM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Any difference with the overdrive on or off, many times the od unit can be the issue. How does the trans fluid look? How is the level?
Low fluid level will mean, no movement. Dirty/old oil will mean sticking valve bodies and the trans may not engage into gear properly.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 03-18-2010, 01:40 AM   #4 (permalink)
Yota4life
I'm thinking of 2 also...I'll start looking around for a used transmission
Old 03-18-2010, 01:43 AM   #5 (permalink)
Yota4life
I haven't tried the O/D off, but it's blinking though.
The trans fluid came out brown. When I did the fluid change, I put in 3 quarts. But after the fluid change, again, car will only go in Reverse, but won't engage in D 2 L, if you rev high (4k+), it'll move slowly....
Thanks for the info guys!
Old 03-18-2010, 01:49 AM   #6 (permalink)
Oooh, yeah, brown trans fluid = burnt to hell and back. Replace the trans fluid and see if anything changes, but chances are your bands are shot to hell.
Old 03-18-2010, 01:49 PM   #7 (permalink)
View Will91's Photo Gallery
The only maintenance item I failed on was transmission fluid. I bought the car new and never had it changed. At about 100k, the 3 speed OD transmission wouldn't shift out of 2nd gear. I took it to a dealer I really trust and they did one of those chemical flushes. The transmission is working like new again. I couldn't believe it. I won't make that mistake again.
You might want to check into this if made my same mistake.
Will91 is offline   Reply With Quote
