temperature question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2010, 01:31 PM   #1 (permalink)
The Great One!
View jelly53's Photo Gallery
okay whenever i drive i have noticed that the temperature needle is alway just little bit below the middle. sometimes it does seem to be in the middle, but most of the time its little bit below. is that a problem? Also I have done coolant flush twice. Thanks
97 Corolla CE 5speed
03 Honda s2000
09 Ninja 250r
jelly53 is offline   Reply With Quote
Old 03-18-2010, 01:37 PM   #2 (permalink)
View Will91's Photo Gallery
On my 96 DX, 1.8 liter, the temperature indicator is always right on the wavy curve - straight across right through the middle.
Will91 is offline   Reply With Quote
Old 03-18-2010, 01:43 PM   #3 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
As long as it's not in the red or not at the C it's generally fine.
cipher93 is offline   Reply With Quote
Old 03-18-2010, 02:11 PM   #4 (permalink)
PatrickGSR94's Avatar
View PatrickGSR94's Photo Gallery
Just below half is what I've seen on pretty much every car I've ever driven, including my 94 Integra and my wife's 96 Corolla.
PatrickGSR94 is offline   Reply With Quote
Old 03-18-2010, 10:12 PM   #5 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Different thermostats will open with a few degrees variance. If you have a cooler 170 deg thermostat to the 192 deg thermostat in my corolla, the needle will move accordingly. With the factory 180 deg thermostat, mine was always a hair below the half mark, with the 192 deg its straight across or just a touch above.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 03-19-2010, 08:01 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Keep in mind the age of our cars. Connections for electrical components are not always clean, tight and transferring electricity at maximum efficiency. Because of that the gauge readings can vary. As pointed out before you only need to worry when the gauge goes WAY up!
-SP
Old 03-19-2010, 04:56 PM   #7 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
Mine is a tad below the middle too, so don't worry it's fine. I just had it changed. The old one was stuck open for the longest time, and in the winter I would freeze my butt off cuz the air coming out of the vents was barely lukewarm at the hottest setting HAHHA..
1994 Corolla
GTChink is offline   Reply With Quote
Old 06-17-2010, 10:24 PM   #8 (permalink)
View artmirza's Photo Gallery
what is wrong with this vehicle 94 corolla 1.8L
trouble code 14, 22,24,52 ?
artmirza is offline   Reply With Quote
