Originally Posted by iToaster
The ECU, maybe wiring, the actuator and cable, plus the lever on the steering wheel. I could see it being a little bothersome, but it's probably not that hard.
Both of my 7th gens have cruise control on them.
I'll start checking junkyards, but if the swap is that involved I'll probably just try a generic aftermarket setup. They run around $250 for everything you need. I'm sure I could find the stuff to do the swap at a junkyard for a lot less but it sounds like it could potentially be a real pain in the ass. Plus, I'm one of those people that goes out to the junkyard and pulls a bunch of stuff but forgets one simple thing I need to make it all work
Thanks.
EDIT: Nationwide junkyard search turned up some results for the servo but the nearest one is 71 miles away and it's $85. And that's just the servo, never mind the speed controller and the column control switch
Looks like aftermarket is the way to go here.
