Radiator questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2010, 11:48 PM   #1 (permalink)
Loneyc's Avatar
View Loneyc's Photo Gallery
gen 7 Radiator questions
Ok my car is not overheating or anything the temp is where its supposed to be, but for some reason when i put coolant in the reservoir its goes from full to low within one day. Also when i opened the radiator cap coolant wasnt visibile. The car wasnt overheating though. I added more coolant in there
Is that normal?
Loneyc is offline   Reply With Quote
Old 03-25-2010, 01:18 AM   #2 (permalink)
View AHarris3719's Photo Gallery
Well considering I got my 95 corolla radiator replaced today, I can tell you that it is a possibility that your radiator is cracked. I'd also check the upper and lower radiator hoses to see if there is any visible liquids in which case your hoses are leaking.
AHarris3719 is offline   Reply With Quote
Old 03-25-2010, 01:39 AM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
You should replace your radiator and both upper and lower hose.. cover all the bases at once.. you have a severe leak somewhere...
Replace all 3 items immediately..
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 03-28-2010, 09:10 PM   #4 (permalink)
View wheredoesthisgo's Photo Gallery
I second that or you will be doing a head gasket very soon.
wheredoesthisgo is offline   Reply With Quote
Old 03-28-2010, 10:19 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
as well as the thermostat.
Old 04-19-2010, 08:32 PM   #6 (permalink)
Loneyc's Avatar
sorry i took so long to reply but i appreciate all the replies
Old 04-20-2010, 08:33 AM   #7 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Bottom line is YOU HAVE A LEAK.
Fix it.
If you dont see a puddle under your car, place some paper or cardboard so you can get an idea where the leak is. The plastic tanks of most toyota rads have a tendency to leak at the seams or crack.
-SP
Old 04-23-2010, 11:29 AM   #8 (permalink)
Loneyc's Avatar
Ok I have the new radiator and I just was wondering how do I go about with flushing the coolant?
Old 04-23-2010, 02:31 PM   #9 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
^there is a drain plug near the bottom of the rad.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 04-23-2010, 02:35 PM   #10 (permalink)
Loneyc's Avatar
thanks
Old 04-24-2010, 08:27 PM   #11 (permalink)
DirtyRolla
Scio_Veritas's Avatar
View Scio_Veritas's Photo Gallery
Did you find the leak coming from the radiator or a hose,have you noticed the leak on the ground?If not check your oil cap for what will look like a vanilla shake,if so you're head gaskets blown and your antifreeze is leaking into you're engine.
Scio_Veritas is offline   Reply With Quote
