Goal would be 150-160hp at the crank. Stock internals, stock ECU. I was hoping to be able to install a small supercharger where the AC compressor otherwise is located. Or perhaps ditch power-steering. This way, one could just remove its drivebelt or the whole thing to pass emissions. If the stock ECU could still manage the bigger injectors there would not be any need to remove them at least. If this is nowhere near enough I'll just skip it and perhaps focus more on the suspension.
I would rather not spend more than $1000 on that project. Clearly, supercharger kits cost way more than that, but junkyard parts can be found cheaper. Turbo chargers or AC compressors can be had for $200. I would be doing all the work myself, but I don't have the tools to take out the whole engine.
Another problem with an engine swap, or any permanent mods for that matter, is all the friggin red tape that is involved. If a particular model did not come with a certain engine over here, forget swapping in anything other than the same motor.
My biggest problem is really to make this an on-off mod which is semi-easy to install/uninstall once a year.
People can fail the emissions test if there is a pinhole leak on the exhaust pipe, with the motivation that it is not possible to properly measure the toxic content of the exhaust gas if the exhaust system is leaking. Sure, clearly one cannot have cracks on the exhaust manifold, but the final muffler? That is just ridiculous.
