Transmission or axle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2010, 12:50 PM   #1 (permalink)
View Suprafreek's Photo Gallery
My sister's car won't move. Its a 1995 Corolla 1.8L. It did this at a stop light and was pushed into a parking lot. The engine is fine but when put it into reverse or drive it makes a grinding noise from the engine/tranny. When I popped the hood I could see the right axle (long shaft) spinning if the car is put in reverse or drive but the car won't move. The left axle does not spin.
Before this the right axle was clicking but just hasn't been replaced. The left axle was just replaced a couple of months ago. Could it be the tranny or just the axle? I'm hoping it's just the axle which is cheaper to fix.
TIA,
Lee
Suprafreek is offline   Reply With Quote
Old 03-26-2010, 01:25 PM   #2 (permalink)
View crabbypaul's Photo Gallery
If the axle shaft is spinning and the wheel is not there must be a problem with the axle or the splines in the hub.
crabbypaul is offline   Reply With Quote
Old 03-26-2010, 11:48 PM   #3 (permalink)
crabbypaul - Thanks, I will look into those.
I had it towed home and the tow truck driver asked if my brakes worked or not because the car moved when he was retracting the tow arm that tows the car. Also when I pushed it into my driveway which has a slight incline the car rolled back like its in neutral and I had to put on the emergency brakes and a log under the rear tires so the car wouldn't roll into the street even though its in park. What does this mean?
TIA,
Lee
Old 03-27-2010, 01:18 AM   #4 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
It sounds like one of the CV Joints on the axles either snapped, or the differential inside the trans is bad... either way..... be prepared for extensive repairs.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 03-27-2010, 08:43 AM   #5 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
And expensive repairs
zythr is offline   Reply With Quote
Old 03-28-2010, 07:30 PM   #6 (permalink)
View wheredoesthisgo's Photo Gallery
cmon
cmon folks. a broken axle is not the end of the world. That is not an expensive repair and i think if the poster has a place to work on it he should give it a go. We can talk you through it. They are not that hard to fix. if its the diff or tranny that could s@ck but have a look at the cv first.
wheredoesthisgo is offline   Reply With Quote
Old 03-28-2010, 10:39 PM   #7 (permalink)
wheredoesthisgo - Thanks for the words of encouragement.
I've done the axles before on a different corolla so I'm not worried if it's the axle, I'm just worried it might be the differential or tranny. But I will find that out when I take out the axle tomorrow. I just haven't experienced this before. Thanks guys for your inputs!
Old 03-31-2010, 11:11 PM   #8 (permalink)
It ended up being a bad axle. It was the joint closest to the tranny that was broken and when the car was put in drive or reverse it would just grind at that point. Power never reached the wheel.
Old 04-01-2010, 01:30 PM   #9 (permalink)
Winner.
Corolla Number TWO
Old 04-25-2010, 09:10 PM   #10 (permalink)
View Steelballz's Photo Gallery
TIA,
Lee
if the long shaft spins, then that CV joint has popped out of the drive...new CV joint time
Steelballz is offline   Reply With Quote
