Check engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2010, 09:46 PM   #1 (permalink)
View Molerj's Photo Gallery
Check engine light---FIXED!
Got some things going on with my '93 corolla with the 1.8 engine with 155,000 miles. Internal engine noise started a few days ago. I haven't heard what a bad rod would sound like but it seems to be there. I was thinking more of a lifter but I don't know. Took off valve cover & top end looks fine. Quit driving it right away. Tried changing oil & adding some of the Lucas oil stuff to see if that helped but it is the same. Engine runs fine, no miss, same power etc. Now, today I started it to see if it miraculously cured itself, which it didn't, but I noticed the check engine light is on. Do I have to go to a dealer to found out what code it is? I don't think the scan tool that I have access to will hook up anywhere on this old of a car.
Molerj is offline   Reply With Quote
Old 03-26-2010, 11:19 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Since your Corolla is a 93, it will be equipped with OBD-I, which means you can do a diagnosis check on it yourself. All you'll need is a paper-clip or a piece of wire. Look in your engine bay and you'll see a small black box next to the driver's side strut tower that says 'Diagnosis' on it. With the paper-clip stretched out (or a bit of wire with both ends stripped), put one end into the port labelled TE1 and the other end into the port labelled E1 (the labels are found on the underside of the diagnosis box cover, much like a fuse-box). Be sure not to clean any of the grease off the connectors as it's there for a reason. Simply just poke through it with the paper-clip or piece of wire.
Turn the key to the ON position, but don't start the engine. If your connections are correct then the check engine light should start flashing. Keep note of how many times it flashes as this is the code it is giving you. For example, if the code was 35 it would flash 3-times, have a short pause, then flash 5 more times, then have a long pause. If it repeats the same code after the long pause then that means it's the only fault detected, if it flashes for a different period of time then that means there is more than one fault. If it flashes continuously with no pauses in between then that means there is no fault detected at all (although since the check engine light is already on, there will most definitely be a fault code detected). Don't worry if you missed the code because it will keep repeating itself until you remove the paper-clip or piece of wire on the diagnosis box. Just be sure to have a pen and paper handy.
Once you've got the code, then head to this website to find out what it means:
http://www.off-road.com/toyota/tech/codes/
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
Molerj (03-26-2010)
Old 03-26-2010, 11:33 PM   #3 (permalink)
Thank you very much, I'll check that out tomorrow.
Old 03-29-2010, 09:13 PM   #4 (permalink)
My trouble code is a 26
Possible Cause of Code/Symptom
Air/Fuel Ratio Rich Indicator
--Same as above
--Cold start injector
So, any ideas of what that means?
Old 03-30-2010, 07:12 AM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Detonation is caused by LEAN conditions not rich.
I havent seen a cold start injector on a car in a long time! I thought that idea was obsolete.
Best idea is to do some maintenance, reset the code and see if it comes back.
-SP
Old 06-02-2010, 08:31 PM   #6 (permalink)
Fixed!
Finally got my car looked at. Fellow found that the timing gear behind the harmonic balancer was bad. He said it was kind of wobbling around and he had a hell of a time getting it out because of that. He changed the timing gear, tensioner pulley & timing belt. I bought the parts. Just paid him for his labor. He surprised me bigtime with the bill........give me some idea what you guys think it should be. I let you all know after I see your estimates. He did say the car runs fine now.
