Changing the air filter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2010, 03:31 PM   #1 (permalink)
View pkcsampoon's Photo Gallery
I have no idea how to remove the hoses to change the air filter for my 96 corolla.
pkcsampoon is offline   Reply With Quote
Old 04-02-2010, 03:58 PM   #2 (permalink)
Gameroom cash: $200810
View ganda1f's Photo Gallery
There should be a screw on the clamp that holds the hose to the airbox. Loosen that screw, and the clamp will slide and increase in diameter, letting you disconnect the hose from the airbox. The hose may be a bit stuck on the plastic, just work it loose.
ganda1f is offline   Reply With Quote
Old 04-02-2010, 04:02 PM   #3 (permalink)
'95 Previa S/C AWD Driver
AlaricD's Avatar
Gameroom cash: $150452
View AlaricD's Photo Gallery
I've never had to undo hoses to replace air filters on any Corolla I've owned. Aren't there just little bails that hold the lid of the air cleaner in place? (Or, in the case of my '76, a wing nut holding the air cleaner onto the carburetor?)
AlaricD is offline   Reply With Quote
Old 04-02-2010, 04:09 PM   #4 (permalink)
I pry all the clips and i can only partially open the lid.
it seems like the hoses hold the lid in place.
Old 04-02-2010, 05:06 PM   #5 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
Unclip the clips..lift up the cover partially, grab filter, pull out, insert new. No need to remove the box LOL
1994 Corolla
GTChink is offline   Reply With Quote
The Following User Says Thank You to GTChink For This Useful Post:
Rip The E Brake (04-02-2010)
Old 04-02-2010, 06:40 PM   #6 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
As above. Just remove the clips.
Here is a picture.... Just unclip these clips, then give the top a good yank until you can remove the air filter.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 04-02-2010, 08:23 PM   #7 (permalink)
Look how silly i am = ="
thank you so much.
you guys ROCK!
