Aftermarket Rear Sway bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2010, 02:00 AM   #1 (permalink)
View prizmster's Photo Gallery
I was looking at a Whiteline rear sway bar for my '94 Geo Prizm. I already have H&R springs with Tokico struts, but it doesn't appear I have a front sway bar from the factory. Will it be okay to by the Whiteline kit and run it w/o a front sway or will I need additional components?
prizmster is offline   Reply With Quote
Old 04-04-2010, 05:17 PM   #2 (permalink)
bump
Old 04-11-2010, 10:45 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1345097
You can just run the rear bar only.
You don't need to get the front if you don't want to.
Old 04-12-2010, 11:55 AM   #4 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
yeah your fwd already understeers from the factory, adding a thick rear sway bar will counter the understeer thus perfect
1994 Corolla
GTChink is offline   Reply With Quote
Old 04-12-2010, 11:59 AM   #5 (permalink)
i know more then you
View Turborolla97's Photo Gallery
Suspension work DIY thread.
this might help that my Boy did if you were to get the front.
Turborolla97 is offline   Reply With Quote
Old 04-24-2010, 10:38 AM   #6 (permalink)
Thanks for the replies. This Whiteline bar didn't come with sway bar bushing brackets (like the Addco does) so I will need to find some. Also it looks like I need a set of endlink bushings. Have anybody gotten this to work on a non-Lsi Prizm or base Corolla?
Old 04-24-2010, 12:33 PM   #7 (permalink)
on full afterburner
The bushing brackets you can buy from a dealer, just bring your RSB bushing to see if it will fit over top.
Are there pre-drilled holes for the mounting points on the underside of the chassis?
If not, you might have to do some measurements and drill them yourself before bolting it on.
