1995 Toyota Corolla DX Electrical Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2010, 09:14 PM   #1 (permalink)
View samtehman's Photo Gallery
Hello,
As mentioned I have a 1995 Corolla. A few weeks back when I pressed on the brake pedal I couldn't shift out of park unless I used the override switch and my brake lights didn't work either. This had happened before and when I took it to a mechanic they changed the fuse and the brake lights and it was working again.
I did the same things and it works momentarily but as soon as I put it in park again (sometimes while I'm driving even) the brake lights will stop working again and I can't shift it out of park without using the override.
Any ideas on what I should try next?
Thanks
-Sam
samtehman is offline   Reply With Quote
Old 04-07-2010, 01:04 AM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Check the bulbs in your tails and high mount brake light...
One of the bulbs is burned out, and fusing the circuit together causing a short.
Change ALL OF THE BULBS, clean the sockets of any corrosion and then replace the appropriate fuse.
Done.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
