1995 Corolla, taking out engine. Have a question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2010, 03:19 PM   #1 (permalink)
View laurgibs's Photo Gallery
I am taking out the engine in my 1995 Corolla because I am swapping it with one from a 94 Corolla. My question is, in order to take out the engine, do I have to take out the transmission as well. Thanks.
laurgibs is offline   Reply With Quote
Old 04-10-2010, 07:13 PM   #2 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
It is advisable. Otherwise, when removing the engine, you'll need something to hold the tranny so it does not fall and get damaged.
zythr is offline   Reply With Quote
Old 04-10-2010, 08:30 PM   #3 (permalink)
View Suprawillis's Photo Gallery
The transmission although little heavy, is a small unit. Yes ideally take them out together since you need to pull both axleshafts anyways, and once the engine is out, it will be easy to check clutch wear if one or both of the transmissions is a manual.
Suprawillis is offline   Reply With Quote
Old 04-12-2010, 09:21 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Its fairly easy to support the transmission without the engine in. You do need enough clearance to separate the two. An automatic only needs a little bit to have the flexplate clear the bellhousing but a manual needs to have the pressure plate come out.
I havent pulled one out of the Toyota so I cant say how much room there is. You'll have to decide.
-SP
Old 04-12-2010, 11:14 AM   #5 (permalink)
blb
View blb's Photo Gallery
I have swapped engines without removing the trans with an automatic, but with a manual trans, you need to pull both at the same time and separate the two outside the car. Since there are three mounts that attach the trans to the car once the engine is out, supporting the trans without the engine is not a problem.
blb is offline   Reply With Quote
Old 04-25-2010, 08:28 PM   #6 (permalink)
View Steelballz's Photo Gallery
I would like to point out that although that may be easier, you actually DONT have to take both out at the same time.I changed my engine in just over an hour without really touching the 'box (bar the bolts and starter of course lol)
Steelballz is offline   Reply With Quote
