'95 Corolla Brake Lights Stay On - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2010, 05:59 PM   #1 (permalink)
View Ashrym's Photo Gallery
Recently I noticed that my brake lights were staying on after I got out of my car. This caused me to have to pump the brakes in order for them to disengage. Unfortunately, I forgot to do this one night and it killed my battery. I went out and purchased a brake light switch based on the diagnosis' I gathered from Googling. This seems to be the best tutorial I've found on replacing it:
http://www.ehow.com/how_5751645_repl...ht-switch.html
However, I can't seem to remove the 4 bolts behind the break pedal to remove the electrical cover for the life of me. I'm using a short-stemmed socket wrench with 1/2 inch socket. This seems to give more much more room and leverage than the adjustable wrench and socket screw-driver I've tried. Does anyone here have an easy way of getting this done?
Thanks in advance,
Mike
Ashrym is offline   Reply With Quote
Old 04-10-2010, 08:34 PM   #2 (permalink)
View Suprawillis's Photo Gallery
The first thing you need to check is the brake light sensor by the pedal. Its just a little push button that is screwed onto your brake pedal brace. When you push in the brake pedal, the pedal releases the button causing the brake lights to engage. when you lift off the pedal, there should be a bump stop on the pedal that pushes the button in. You just need to adjust the sensor by either screwing it in further/unscrewing it enough to where the bump top on the pedal pushes the sensor button all the way in.
Suprawillis is offline   Reply With Quote
Old 04-11-2010, 12:30 AM   #3 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
i though that on my car it was just 2 jam nuts that held the switch into place on an arm near the pedal arm. just loosen the nuts and unscrew the switch.
