Engine running over normal temp
Hi guys, I got a problem with my engine. I own a 95 Corolla jap spec. It used to have a 2E 1.3L engine, I swapped to a 3E 1.5L.
After cold starting after 10 mins it will run over 176ºF and with normal driving it will go past 212ºF which is redline and goes over.
I placed a new radiator in, checked water pump, checked thermostat, checked fan, checked all hoses. Rad fan kicks in but when it goes past 212ºF, kinda late. All this time I have to run with the fan permanently on which it shouldn't.
My engine is stock, no mods, only shaved head which yields 10.3:1 compression. Weird thing is that my old 1.3L used to have 11.0:1 compression and never had overheating problems.
Do you think it can be a bad thermoswitch or is it the compression raise?
Thanks for your advice!
