Able to move wheel back & forth by hand? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2010, 08:45 PM   #1 (permalink)
View Dodgerdart's Photo Gallery
I have a 94 Prizm and had the front driver's side wheel jacked up. I was able to move the wheel(loose play) in any direction, horizontal and vertical. I took the wheel off and put my lug nuts on the rotor and was able to move the rotor. Nothing else moved but the rotor. I did try to search other post and it sounds like it's probably gonna be a wheel bearing. I don't hear any bad bearing sound when I spin the wheel by hand. Could it be a loose axle nut?
Dodgerdart is offline   Reply With Quote
Old 04-15-2010, 10:10 AM   #2 (permalink)
If I get a hub from a junk yard will one from the frontpassenger side work on the driver's side? Does each wheel hub have two bearings in it?
Old 04-15-2010, 04:31 PM   #3 (permalink)
View Suprawillis's Photo Gallery
The only way the axle nut could get loose, is if the cotter pin was missing. If it is missing, then try torquing it down. Uses a rather large socket. Other than that ounds like a wheel bearing. Don't drive on a bad enough wheel bearing that you can wobble things around, your whole wheel/hub assembly can come off on the fly.
Suprawillis is offline   Reply With Quote
Old 04-15-2010, 06:23 PM   #4 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
Probably the bearing. Its not worth pressing out a used hub and putting it in. With the work involved, just get a new one and do it right unless you can get the whole assy from the wrecker. The assy is side specific, the bearing and hub isn't
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 04-16-2010, 01:30 PM   #5 (permalink)
View Steelballz's Photo Gallery
try tightening the driveshaft nut first, long 30mm socket needed.if that doesn't solve the problem, it'll be wheel bearing.
and if you don't have a bearing press, just get another hub from the scrapyard
Steelballz is offline   Reply With Quote
