A/C Belt Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2010, 10:29 PM   #1 (permalink)
View MissPatricia's Photo Gallery
I am going to buy the new belt tmrw... but have no idea how to change it!
Is it really complicated? And is there a switch or lever to move so I can put the belt on? Any help would be very appreciated as Im finding it hard to find anything on changing the belt for the A/C... I have a 94 toyota corolla...
MissPatricia is offline   Reply With Quote
Old 04-18-2010, 08:05 PM   #2 (permalink)
DirtyRolla
Scio_Veritas's Avatar
View Scio_Veritas's Photo Gallery
Loosen the idler pulley lock nut(the top pulley in the pyramid)then turn the adjusting bolt(above the pulley,to the left of the alternator)turn till there is enough slack to remove the belt off the crankshaft pulley.Since it's off you might as well change all your belts,they are fairly inexpensive and should wear relatively all at the same time.Do in reverse for install.
When you replace the belts,to ensure proper tension you'll need to use a belt tension gauge,if you can not use one.Lay a straight board or something straight that carries from pulley to pulley,you then need to place pressure to the belt in the center of each pulley, then measure with a ruler the distance between the belt and the straight object.for a 7"-11" span it should go a 1/4",for a 12"-16" span it should deflect 1/2"
Scio_Veritas is offline   Reply With Quote
Old 04-19-2010, 09:57 AM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
And dont forget to check the tension again in a few hundred miles.
New belts stretch.
-SP
