Lost gears? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-18-2010, 08:56 AM   #1 (permalink)
View 95Toyota95's Photo Gallery
Lost gears?
I was driving the other day and started realizing that 2nd gear was taking me a few extra seconds to find. eventually i couldn't find it and 4th and reverse. but 1st 3rd and 5th gears are still perfect and there. its just the bottom 3 on the stick shift. does anyone know the problem. is it the whole clutch, or i've heard its a simple pin in the gearbox. if anyone knows the problem cud they tell me, thank you
95Toyota95 is offline   Reply With Quote
Old 04-18-2010, 09:02 AM   #2 (permalink)
Proud 93 Corolla owner
TI-CAVA's Avatar
View TI-CAVA's Photo Gallery
chack the cables that go to the gearbox, coming from the stick shifter
Corolla 93 1.6l 89Kw DIY mods
Intel Pentium 4 Northwood D1 @ 2.9 GHz HT,Intel D865PERL,4Gb PC3200 DDR Dual channel, ATI 9600 AGP8X 256 MB,SP0411N,ST340015A,PCTV 110i, Logitech Attack 3.
rate! NOW WITH HIGH RES PICS!! 3.2Mp
TI-CAVA is offline   Reply With Quote
Old 04-19-2010, 09:32 PM   #3 (permalink)
Before "THE WRECK"
sequoiasoon's Avatar
iTrader Score: 7 reviews
View sequoiasoon's Photo Gallery
There are a couple rubber grommet/bushings on top of the tranny where the cables attach. One has probably deteriorated so now won't move the linkages correctly.
'93 Corolla getting parted out. Will be scrap REAL SOON so TELL ME WHAT YOU WANT OR NEED!!! Pictures and videos here http://s700.photobucket.com/albums/w.../parts%20left/
sequoiasoon is offline   Reply With Quote
Old 04-19-2010, 10:19 PM   #4 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
If its not the linkages or the bushing, could be a broken or bent shifter fork in the transmission, usually caused when you miss shift/grind the trans or try jamming it into gears, usually the 1-2 shift.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
