door lock question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2010, 02:18 PM   #1 (permalink)
View snipes400's Photo Gallery
door lock question
The door lock for my driver seat door has stopped working, and I don't really want to buy a new one if I don't have to. Is it possible to just switch the right and left door locks around, or are they different somehow so that they wouldn't fit?
Thanks
Additional info:
97 corolla
4 doors
power locks
1.8L engine
snipes400 is offline   Reply With Quote
Old 04-23-2010, 06:54 PM   #2 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
just get a new one or a used one from the junkyard thats working it wont make sence switching them cuz u still will be left with one door lock not working.....not sure about them all bein the same for a switch tho
topnotch is offline   Reply With Quote
Old 04-24-2010, 12:09 AM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
If you are talking about the lock cylinder, they can usually be "fixed" with some lubrication. Look on the shelves for some "Lock ease."
-SP
Old 04-24-2010, 02:02 AM   #4 (permalink)
DirtyRolla
Scio_Veritas's Avatar
View Scio_Veritas's Photo Gallery
The actual door lock cylinder is not interchangeable,being a right and left unit.It would only be backwards in an attempt to switch.Most parts stores sell these as a package deal,so your best bet is finding a junkyard.All of 93-97 locks will work so you have a good range of possible old Corollas being in the yard.If you want brand new, shop online the cheapest I saw in a set was 25$,for both lock cylinders and keys.Good luck
Scio_Veritas is offline   Reply With Quote
Old 04-29-2010, 07:09 PM   #5 (permalink)
Coconut
View Jigerotta's Photo Gallery
door solution
i've had similar problem, my drivers' door lock didn't work properly - the key didn't turn. well, once my husband accidentely opened that lock with his Honda key since then it always work.i mean i'm not sure if that door can be open with any key now, but it is what it is - the lock works
Jigerotta is offline   Reply With Quote
Old 04-29-2010, 09:14 PM   #6 (permalink)
KenLayton's Avatar
View KenLayton's Photo Gallery
I took both my front door lock cylinders out and sprayed them out with wd-40. Then, since I had the door panels off anyway, I greased all the door lock linkages. The locks work real slick now.
KenLayton is offline   Reply With Quote
Old 04-29-2010, 09:29 PM   #7 (permalink)
yeah I've tried using lubricant, but it only helps for a little while. After a bit of use the lock goes back to being getting stuck all the time. I guess I can try and take it out and see what other parts of it I can apply wd-40 to (besides the keyhole).
Anyway thanks everyone.
Old 04-29-2010, 09:40 PM   #8 (permalink)
View liensalebuyer's Photo Gallery
I had a similar problem, I thought someone tried to gum up the lock cause it was difficult to unlock. I re cut the key at the local hardware store that uses Access keys and works fine now. Access keys are cheaper metal, but it doesn't take force to turn and unlock now. Worst comes to worst, dealer can cut the key by VIN for $8 to $10 or if you have a coupon for 15-20 percent off, even cheaper.
liensalebuyer is offline   Reply With Quote
