Installing Extended Studs on rear drums - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2010, 08:04 AM   #1 (permalink)
View Superwhite2005's Photo Gallery
so im having an issue with my rear tires rubbing against the perch of the strut, so in order to fix this i had to purchase 1/4" (6mm) spacers so that the wheel could clear the perch. Now i want to install extended studs in the rear drum brakes to compensate for the spacer however i have never done this on a car with drum brakes.
has anyone here installed extended studs on these type of brakes?
Do i need to press out hub?
Superwhite2005 is offline   Reply With Quote
Old 04-26-2010, 02:51 PM   #2 (permalink)
View Steelballz's Photo Gallery
all you need to do it take off the drum, hammer out the old studs out of the drum, and then carefully press in the new extended studs (carefully as you dont want to ruin the threads lol)
I havent done extended studs, but had some normal studs snap, inevitably foring me to replace them so I speak from previous experience
Steelballz is offline   Reply With Quote
Old 04-26-2010, 06:02 PM   #3 (permalink)
corolla96's Avatar
View corolla96's Photo Gallery
http://www.ichibausa.com/toyota.html
just hammer out the old ones and use the impact gun to tighten them??
K&N SRI, TRD FSB, Magnum Steel Braided Brake Hoses, Depo Black Housing Headlights Set, Clear Signal Lenses, 9006 6000K HID, LED corner lights, lic. plate lights, trunk lights, Ractive Sport Pedals, 20% tint front, 5% tint rear, Freeway TCD-0361-1 Deck, custom front grille
corolla96 is offline   Reply With Quote
Old 04-26-2010, 09:36 PM   #4 (permalink)
what do you mean hammer them out of the drum, are the studs attached to the drum or the hub bearing?
Old 04-27-2010, 08:05 AM   #5 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Dont forget that hammering can damage the bearings. The best way is the remove the hub and press them out. BUT usually most use an air chisel. There may be room behind the hub to get the old studs out but there might not be enough room for the new ones.
Studs are friction fit with a spline.
-SP
Old 04-27-2010, 03:27 PM   #6 (permalink)
Super Procrastinator
modernage's Avatar
View modernage's Photo Gallery
I just sprayed it with WD40 and hammered them out but not super hard. It was kinda hard to slide the normal studs in the back so I'm guessing extended studs would not work so your better off taking the hubs out. Are your fenders rolled? Your tires will be sticking out more now so when you hit bumps you'll most likely hit the fenders now instead of your struts.
modernage is offline   Reply With Quote
