Soft/Spongy brake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2010, 10:33 PM   #1 (permalink)
View sidclaim's Photo Gallery
Question Soft/Spongy brake
95 Toyota Corolla, replaced both rear wheel cylinders and pads. Bleed-off all four wheels. The brake feels like spongy. When approaching stop light, pressing on brake pedal and there's a light drop or softness. Is this normal? I have to re-pump the brake.
sidclaim is offline   Reply With Quote
Old 04-27-2010, 11:25 PM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
There is still air in the lines... bleed them again... if still the same result, check for hairline cracks in the calipers, or drips in the connecting lines...
If to no avail, check booster.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 04-28-2010, 02:08 AM   #3 (permalink)
Super Procrastinator
modernage's Avatar
View modernage's Photo Gallery
I have this same problem on my Explorer right now and have bled the brakes 3 times to get all air out. I've also replaced my brake master cylinder and it was the same. My next step is to replace the brake lines since they're the original.
modernage is offline   Reply With Quote
Old 04-28-2010, 05:14 AM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
When bleeding brakes always start with the FURTHEST wheel from the master cylinder. Easiest way is to use a mityvac pump, but when you use a second person pushing the pedal for you make sure you close off the bleeder before the pedal reaches the bottom.
These rules will be different for vehicles with ABS.
Old brake HOSES can make for a "soft"pedal as the rubber ages BUT you wont get any change in pedal feel when you pump it. Pumping compresses the air bubble(s).
-SP
Old 04-28-2010, 02:01 PM   #5 (permalink)
View Steelballz's Photo Gallery
random thought, but are both driveshafts completely tight?
had a similar problem on my corolla lately, tried changing all pads to start with and problem kept coming back, air-gunned the 30mm drive nuts into place and that solved the problem.
just as food for thought
Steelballz is offline   Reply With Quote
Old 04-28-2010, 07:41 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
That wouldnt cause "spongy" brakes but it would cause excessive pedal travel from more than typical runout of the brake disks.
-SP
Old 04-29-2010, 05:50 PM   #7 (permalink)
I had it in my car, and usually had to pump the breaks to have normal breaking, so I stand by my statement
Old 04-30-2010, 08:57 AM   #8 (permalink)
96 prizm LSI
View JDMprizm's Photo Gallery
Same thing happend with my Prizm...
Replaced everything to do with brakes.
JDMprizm is offline   Reply With Quote
Old 05-01-2010, 05:16 PM   #9 (permalink)
My car's name is Kerolla!
View brown0809's Photo Gallery
I had that problem with my 96 Corolla, I changed the master cylinder and that fixed it.
brown0809 is offline   Reply With Quote
