95 Corolla DX smells like gas after driving - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2010, 12:41 PM   #1 (permalink)
View samtehman's Photo Gallery
I looked below the car after driving and there appears to be dripping fuel under the passenger/driver seats. I was going to take it to get it looked at but I thought I'd ask here if you had any suggestions?
My Dad seems to think it might be the fuel filter
Thanks,
Sam
samtehman is offline   Reply With Quote
Old 05-03-2010, 12:51 PM   #2 (permalink)
View Ludapower's Photo Gallery
Fuel lines, Gas tank, fuel filler pipe. Check those.
Rust is your enemy.
Ludapower is offline   Reply With Quote
Old 05-03-2010, 01:31 PM   #3 (permalink)
BigDAT's Avatar
View BigDAT's Photo Gallery
USA
Rust is your enemy.
Exactly what i was gonna say, however I like the smell of gas
BigDAT is offline   Reply With Quote
Old 05-03-2010, 02:16 PM   #4 (permalink)
Same here, that's why I haven't replaced my fuel filler pipe yet. Also because it's $100 for a pipe.
Old 05-03-2010, 02:29 PM   #5 (permalink)
Super Procrastinator
modernage's Avatar
View modernage's Photo Gallery
Ehh I prefer the smell of carbon monoxide.
Joking aside, seeing as how you're from Ohio, rust might be the reason like what everyone said. I'm fortunate enough to live where it doesn't snow so I don't have that issue. Mine does smell when the car is in the garage after I drive it or if I start it for the first time in like a week but I think that's normal.
modernage is offline   Reply With Quote
Old 05-04-2010, 09:03 AM   #6 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You could get lucky and just a hose is loose or needs replacement, but the lines from the fuel tank take a lot of abuse form our salty winters. Pull out the seat, and check where its leaking.
-SP
Old 05-04-2010, 01:26 PM   #7 (permalink)
Thanks for the help guys
Also on an unrelated (possibly related?) note, I also noticed my brakes had more give to them yesterday and it seems like on a slant that the pedal seemed spongy and even when I had it pushed all the way to the floor the car rolled to a stop
I haven't had any brake problems prior to this and the brakes were done a year or two back
Old 05-04-2010, 01:46 PM   #8 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
Sounds like your fuel lines have a leak in them given the location of the leak. I don't know what your mechanic will say, but mine has quoted me $400 for parts/labor to make and install new lines to give you an idea.
cipher93 is offline   Reply With Quote
Old 05-06-2010, 08:16 PM   #9 (permalink)
The fuel AND the brake lines were rusted through. $500 to fix them but on the plus side the mechanic said besides a leaking radiator hose the car is in excellent condition. I will hold onto this one for another year or so
Old 05-08-2010, 09:43 AM   #10 (permalink)
View redlinerev's Photo Gallery
ya, I went through this, I would replace it before it starts dumping. If is is a rotted feed line, like mine was it will start with drips, then eventually just dump loads of gas, very unsafe.
I changed mine myself, they actually had one IN STOCK at the dealer. The guy said they sell a lot of them - too bad it isn't a recall.
I think the line was around 80 bucks, but I also had to get the piece that goes between the tank and the main feed line, because the fitting was impossible to loosen, even after a day of soaking with PB Blaster. This piece was another 40, and they had to order it.
The job only took about and hour of so, it wasn't that bad, and I was working on the ground, not on a lift.
Luckily the end at the fuel filter was not an issue. It broke loose easily.
Hmm, no leak at the brake or return lines yet, but maybe I will replace them this summer, just in case. I left the plastic cover off, because it seems like it helps hold moisture against the lines.
Good Luckl
redlinerev is offline   Reply With Quote
Old 05-09-2010, 05:56 PM   #11 (permalink)
View Suprawillis's Photo Gallery
The fuel filter is in the engine compartment under the EGR canister. If you remove the backseat, you will have access to the gas tank. I have replaced mine before, and these things are highly pressurized. So if you have a crack in the tank, things like gas tank repair kits and JB weld sometimes aren't strong enough to seal the crack. If you are near a local junkyard then chances are that they have a few rollas. You can get lines, or a tank for cheap.
Suprawillis is offline   Reply With Quote
Old 05-14-2010, 12:04 PM   #12 (permalink)
View hungt1999's Photo Gallery
Good Luckl
You need to drop the fuel tank to change the 2 lines that goes into the tank right? I ordered the main fuel line and return line last year, it only goes to near the tank then there are 2 separate sections that goes into the tank
hungt1999 is offline   Reply With Quote
