What are THESE made of....? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2010, 05:29 PM   #1 (permalink)
Gameroom cash: $130405
View snoofer's Photo Gallery
Aluminum.......Chrome.........Other.....?
I'd like to clean these up, but dont know how to start. I did a small portion using a round piece of scotchbrite in a drill with excellent results.
And I'm sure I will need to use some kind of polish afterward....but have NO clue which kind to use.
Am I doing damage by using the scotchbrite pads...? Please Help.
http://www.flickr.com/photos/35337395@N04/4576526804/
http://www.flickr.com/photos/35337395@N04/4576527330/
snoofer is offline   Reply With Quote
Old 05-03-2010, 05:55 PM   #2 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
did you try spray wheel cleaners first...then just use a brush for wheels....I wouldn't go with scotch pads at first try.
1994 Corolla
GTChink is offline   Reply With Quote
Old 05-03-2010, 05:56 PM   #3 (permalink)
BigDAT's Avatar
View BigDAT's Photo Gallery
looks like aluminum, but I cant tell, tap on it, you can tell by the ring
BigDAT is offline   Reply With Quote
Old 05-03-2010, 06:16 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
they're clear coated aluminum. its best to get them stripped and refinished since if you clean them to bare metal you've just removed the protective clear coat.
Old 05-03-2010, 06:17 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1345097
Mothers and Meguiars sell a variety of wheel polishes over the counter. Either one should be more than adequate to restore those wheels.
Old 05-03-2010, 06:28 PM   #6 (permalink)
Tried spray and took it to the carwash n used the brush, but no luck.
I'll try the Mothers or Meguiars for Aluminum...... Thanks
Old 05-03-2010, 08:01 PM   #7 (permalink)
Bitter's Avatar
except the damage is IN the clear coat and eaten through partially into the wheels. so the clear has to be stripped to repair the wheels (if it got that far) and they need to be recleared. they'd probably just be OK getting stripped and repainted.
try brake and parts cleaner (the green bottle, not the red bottle) and a pressure washer along with dish soap and a stiff brush.
The Following User Says Thank You to Bitter For This Useful Post:
Rip The E Brake (05-04-2010)
Old 05-04-2010, 09:01 AM   #8 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
+1 on bitters comments. It will be hard to make these wheels look good since the clear coat is damaged. Refinishing is your only hope.
And they are aluminum.
-SP
