4age to 7afe head swap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2010, 11:38 PM   #1 (permalink)
I will beat a VW Golf 2.0
View crollaondubs's Photo Gallery
I've been searching around trying to find a straight anwser to this question. I'm looking at adding hp to my 96 7afe. What i want to know is can you swap the head from a 4age to a 7afe? And also what exactly what i need to do this and roughly what hp i might gain if i do so. Or would i be better off swapping out the 7afe for a 4age. I'm looking at adding hp on a budget, but if i need to spend the money i will.
Also how hard is it to do an automatic to manual conversion? and is it possible?
Any and all help would be great.
Thanks
crollaondubs is offline   Reply With Quote
Old 05-04-2010, 01:04 AM   #2 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1340866
iTrader Score: 7 reviews
I would think that this would be possible as I was trying to put a 7A block with my 4AGE head on my old 88 Corolla GTS. I was told that it would be easy to swap out for the stroked 7A block & that the 2 blocks were the same outside. I'm sure that others can confirm if this is true.
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 05-04-2010, 06:41 PM   #3 (permalink)
Saloon Fanatic
View 1jzdreamer's Photo Gallery
You can, its been done, its not cheap, but it is an awesome build and will be a good motor when done. The redline will be around 6500 though as the 7afe crank won't take much more.
20v, 6 spd lsd
Boost, may you RIP.
Corners Quickly...
1jzdreamer is offline   Reply With Quote
Old 05-04-2010, 07:31 PM   #4 (permalink)
Loneyc's Avatar
View Loneyc's Photo Gallery
honestly just do the full engine swap and tranny swap
i dont regret doing it
it just depends on your budget i guess
Loneyc is offline   Reply With Quote
Old 05-04-2010, 10:20 PM   #5 (permalink)
i know more then you
View Turborolla97's Photo Gallery
Thanks
Yes
yes
Yes
http://www.wheelsjamaicahost.com/whe...topic=119806.0
http://te51levin.superjamie.net/7agebuild.html
http://www.aeu86.org/index/engine-4a...156/post=60902
Turborolla97 is offline   Reply With Quote
Old 05-08-2010, 11:56 AM   #6 (permalink)
View perrone721's Photo Gallery
i was interested in this as well but i found out it is rather exspensive but you do get great hp gains
you need the 4age/ze head, 4agze pistons, the 7a rods work but new OEM are preferred, also out off a 4a engine you'll need the fuel lines, injectors, fuel pump, as well as the ECU
after hearing this and looking for parts and prices i decided to just build my 7a and turbo down the road and just run low boost
1994 Celica
perrone721 is offline   Reply With Quote
