Ok, what the $%^&* is wrong with these brakes?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2010, 05:42 PM   #1 (permalink)
View vmax84's Photo Gallery
I thought it needed a master cylinder.
1997 Corolla with 1.6 liter, automatic, no ABS. Car stops fine, but the pedal goes almost to the floor to do it. It has been doing this since about 5 years ago, when I didn't start the car for about 5 months. I had the vehicle in storage for those 5 months, and when I started it and put my foot on the pedal, it's almost like something "let go" and the pedal went further down than normal. LIke I said, car still stops fine, and in recent history, put front and rear pads on it, didn't notice any leaks from calipers or wheel cylinders........
so, I thought the only thing left was the brake master cylinder, which I replaced today. Bench bled the cylinder, installed, and gravity bled the brakes.......didn't seem to feel any different than what it did before? Vacuum boost shot?
My 1995 Corolla brakes start working almost the moment you start stepping on the pedal.........what's going on here?
Am giving the 1997 Corolla to my daughter who just turned 16, so want to make sure the brakes are without question 100 percent.
Thanks for any ideas.
vmax84
vmax84 is offline   Reply With Quote
Old 05-11-2010, 11:48 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
If you get a hard pedal but the pedal travel is too much it because the master cylinder has ti pump too much fluid SOMEWHERE. Usually its the rear brakes arent adjusting and need it. SOmetimes its a badly warped disk that pushes the pads too far out.
The booster only affects pedal effort.
I suspect you still have air in the lines after replacing the MC. Gravity bled??
-SP
Old 05-12-2010, 12:03 AM   #3 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
rip up the parking brake a few times, and the rear brakes should adjust correctly...
Sounds like dry rot on the rubber lines somewhere... look for wet joints or leaking brake fluid..
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 05-12-2010, 07:58 PM   #4 (permalink)
Good suggestions so far. I popped the hubs off the rear wheels to confirm the rear cylinders weren't leaking......they weren't. Pulled up a couple notches on the emergency brake and both wheels locked up (had the car up on jacks).........emergency brake goes about 3/4 of it's travel and locks up tight with the rear wheel tightened down hard.
Need to get my buddy over to have him pump up the brakes and bleed them this way. Looked at the rubber brake hoses, but they looked ok.
Thanks for the suggestions.
vmax84
Old 05-14-2010, 11:47 AM   #5 (permalink)
blb
View blb's Photo Gallery
Manually adjust the rear brake shoes until they just start touching the drums. If that doesn't fix it, pull each of the front calipers and make sure the bushings that the mounting bolts slide through will slide easily back and forth in the caliper body.
blb is offline   Reply With Quote
Old 05-14-2010, 05:24 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
I second that IF you actually have all the air out of your lines.
-SP
