Power steering issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2010, 08:26 PM   #1 (permalink)
jt14894's Avatar
View jt14894's Photo Gallery
Question Power steering issue
Got a strange leak with the power steering in my rolla. I have to keep refilling the reservoir once a week. I don't see any oil spots when I look under the car and so I don't know where to look for any leaks. The last time I took it to my trusted mechanic, he checked and couldn't find the leak either. The only thing he suspects is that the fill cap may not be sealing properly when closed.
Has anyone experienced this?
2010 BMW 335i: Auto/STEPTRONIC shift
2005 Mustang GT:5-spd, K&N CAI, DiabloSport Tuner, Ford Racing Axle-backs
1997 Corolla CE: 5-spd, K&N
1983 380 SL Benz: K&N
jt14894 is offline   Reply With Quote
Old 05-11-2010, 08:36 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
are the rack boots full of fluid?
Old 05-11-2010, 10:06 PM   #3 (permalink)
jt14894's Avatar
Sorry for the being a novice, but how do I check the rack boots?
Old 05-11-2010, 10:43 PM   #4 (permalink)
View musclecar64's Photo Gallery
Get under the car. Locate the tie-rods. Trace them up to the rack. Find the boots on the rack (one on either side of it). Remove the clips holding the boots on the tie-rods. then you can pull the boot back and look inside it. Hope that helps. A haynes manual would also help.
musclecar64 is offline   Reply With Quote
Old 05-12-2010, 09:31 AM   #5 (permalink)
View C-Mo's Photo Gallery
Turn on the car and watch under the hood while someone turns the wheel from stop to stop. I've had pinhole leaks on my pressure hose that literally shoot fluid while the car is on, but don't leak at all when it's off.
C-Mo is offline   Reply With Quote
Old 05-12-2010, 10:23 AM   #6 (permalink)
I just had to replace my power steering pressure hose for the exact same reason. You wouldn't even know there was a hole in that hose until you applied pressure it was so tiny, but it leaked fluid like crazy.
Old 02-10-2011, 02:31 PM   #7 (permalink)
jt14894's Avatar
Sorry for the late late late late late update. I've been MIA for a while.
I had my trusted mechanic check it and the power steering pressure hose was definitely the culprit.
He replaced it and now no more leak.
