BZ Touring heat mixer problem
Thanks heaps for the replys!! The blower doesnt always run at full. It does operate as it should from low to high, its only when i switch it to auto that it stays at full. As for the temp, all the linkages seem to be fine. I do get heat, and good heat at that, but i only have the 2 options, cold or well hot. I cant mix cold and hot together to get a medium heat shall we say. I have seen a solution before but cant find that solution again. There was a similar description and the one solution was an easy part to replace but cant remember the part. From what i remember it was a plug in part that was fairly small and covered by a heat sink.
