weird grinding/scraping noise??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2010, 06:45 PM   #1 (permalink)
AE-202 Owner
miib14's Avatar
Gameroom cash: $356141
View miib14's Photo Gallery
hi, got a problem which i need urgent help with....
it started yesterday after i had to do an emergeny brake,
the noise is coming from the passenger side....can really hear and it gets louder as the car slows down... and quiter as the car picks up....
really annoying me..
can anyone help please.....
thanks
★ 1993 Toyota Corolla Saloon ★
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
185 Bhp & 142 lbft Torque
miib14 is offline   Reply With Quote
Old 05-14-2010, 09:43 PM   #2 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Its the rear drums/shoes.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 05-15-2010, 03:25 AM   #3 (permalink)
AE-202 Owner
miib14's Avatar
so just need to get them changed?
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
Old 05-15-2010, 01:59 PM   #4 (permalink)
corolla96's Avatar
View corolla96's Photo Gallery
same here
it sounds like you are machining the rotor. and it's from the rear wheels of the car.
K&N SRI, TRD FSB, Magnum Steel Braided Brake Hoses, Depo Black Housing Headlights Set, Clear Signal Lenses, 9006 6000K HID, LED corner lights, lic. plate lights, trunk lights, Ractive Sport Pedals, 20% tint front, 5% tint rear, Freeway TCD-0361-1 Deck, custom front grille
corolla96 is offline   Reply With Quote
Old 05-15-2010, 02:26 PM   #5 (permalink)
AE-202 Owner
miib14's Avatar
its not from the back, its from the front....
took the wheel off and the sound got worse....
it doesnt even sound like its scraping or grinding!
heres a vid of what it sounds like....
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
Old 05-15-2010, 02:47 PM   #6 (permalink)
AE-202 Owner
miib14's Avatar
Originally Posted by subzerounlimited View Post
i had a similar type problem with a screeching noise being emitted from my front wheels at highway speeds. i did a brake change out from caliper to rotors and i still had the same problem. its was only after i changed the bearings the noise stopped. the difficult thing about the bearings in front though is that they are kept in place by the velocity joint axle which is fastened with a huge nut. so if you try to rock the wheel you may not get any movement. another way to check the bearing is the lift the car of the ground rotate the wheel by hand and feel for any rough movement in the axle or any grinding noise.
when i did all of these tests i still got nothing. i ended up changing the bearings after doing a risky thing which i will not recommend. i chocked my car in place raised one wheel ,of the ground took off the tyre and ran the car no more than 60km/h without the wheel on that side. when i heard the noise it was definitely coming from the bearing area...
and yes there are bearings in the rear wheels as well...
hope this helps..
from the other topic but got a really weird feeling that it may be the bearing....
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
Old 05-15-2010, 08:29 PM   #7 (permalink)
View Suprawillis's Photo Gallery
It's probably your brake pads. If they are going metal to metal, then they will get louder as you slow down. They are a piece of cake to replace. You can also check the thickness of the pad while the wheel is off.
If the brake pads are okay, grab the disk with your hands (make sure it i cool) then move back and fourth to check any movement between the whole disk assembly, and the hub. This will tell you if you have a bad bearing.
Then check and make sure the bottom of the dust cover isn't grinding against the rotor.
Suprawillis is offline   Reply With Quote
Old 05-15-2010, 10:25 PM   #8 (permalink)
A. Brake Pads. OR CALIPER BRACKET
B. Wheel bearing.
C. outer CV axle joint
D. Dust Cover.
Corolla Number TWO
Old 05-16-2010, 03:52 AM   #9 (permalink)
AE-202 Owner
miib14's Avatar
thanks for all the advice, took it to a mechanic and he said its the bearing gone...
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
Old 05-18-2010, 03:49 PM   #10 (permalink)
AE-202 Owner
miib14's Avatar
it was the bearing....
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
