Originally Posted by 4EAT4ME
Thanks for the awesome reply! I did just that and everything looked good. It appears the cap/dist unit is newer but the wires are original. I have a new problem posted above...do you think the wires may be attributed to this?
It could always be a tuning issue. However have you ever pulled the intake manifold off and cleaned the inside with gunk?
If not prepare to get real dirty. Some will say that you can run sea foam through the intake and that will clean it through. Be that as it may in most vehicles, if your corolla has 192k miles and never cleaned the inside of your intake manifold, trust me there is some thick black cake in there. Your entire EGR system could be clogged as well.
At times this may, or may not throw a CEL code, but I have almost 360k miles on my rorra, and it has never thrown a code for clogged up intake manifold. Okay so here we go. 1st, go to lowes or home depot and get one of those cheap paper painter's suits. Or just find raggety clothes. An get about 2 cans of chemtool, and 2 cans of brake parts cleaner from autozone.
Now. Remove your air filter box.
-Next I am trying to remember off the top of my head, remove the throttle body. Disconnect the cable by pulling the throttle all the way down with your thumb, and slide the cable end out of the throttle body. Undo the two 12mm bolts and the two 12mm nuts. Pull the water hose, and vacuum hoses out. Get masking tape, write with a sharpie on which hose goes to what port on the throttle body. Make sure you remember how the throttle body gasket goes on the intake.
-Next there is 4 allen head style bolts holding the top part of the intake manifold on. I thiiiiink there are also a few 12mm bolts/nuts holding it on.
-Pull the top of the intake manifold off. You should have to remove a few vacuum lines which are PCV, and the other is just an intake source. Also on the lefthand corner should be a fuel pressure regulator vacuum source. Pull that off.
-Mkay at this point if I hadn't listed everything, there shouldn't be much to do, lift the top of the intake manifold off and be very careful with the intake manifold gasket. Because if you bend it, it can be bended back together, but if it doesn't seal right, then your idle will be high.
-Now we should have cake!!! Thick heavy oily cake! Get a wire brush, BE SURE TO USE RUBBER GLOVES GOTDAMMIT!! Spray the chemtool and get it good. Black spatter will get all over you, all over your engine bay, just allllll over!! If you have a shop vacuum, Great! this would be handy to suck out access puddles of chemtool. WEAR EYE PROTECTION GOTDAMMIT!! Chemtool will burn holes in your skin. Ask me how I know.
-If you have access to an air compressor, grrrrreat! You could spray out access residue that got inside your valves, etc.
