Okay so there are a few things you can do.
First, check the compressor wire and make sure it has not disconnected itself. It is very deceiving, and it is just a single wire that can easily be overlooked. Look under the alternator, and you should find the wire attached to a small clip going into the compressor. I just noticed this last week and now my AC is back to normal, which brings me to my next suggestion.
If you jack up te passenger side, and undo the plastic splash guards(they are held on with a few 10mm bolts). You will have access to the AC compressor pulley.
There is one 10mm bolt holding it on the clutch to the pulley. When the AC is off, the clutch is stationary, and does not move with the pulley. Now turn on the AC, and if the clutch spins, this will tell you that compressor is working, and that the clutch still has good engagement. If it does not spin, then this tells you that the clutch is worn out.
It is a fairly simple fix. If you have to remove the clutch, you will need one of those oil filter removal tools and fit it over the pulley. This will keep it from spinning while you loosen the 10mm bolt.
When it is loose, take the bolt out and the clutch should come out. Now this is where you need to pay attention. When you remove the pulley, a shim will fall out. This shim fit around the bolt when inside the pulley, acting as a spacer because the when the AC is activated, the compressor becomes internally magnetic pulling the clutch in, so that is mates with the compressor and spins.
If you have more than one shim, remove one, keep the other installed, and turn on the AC and see if the compressor "grabs" or pulls the clutch in enough to spin it.
Now of course, if you don't care, you can remove the shims altogether and when you re-install that 10mm bolt that holds the clutch to the compressor, you will have 24/7 AC. That shim is designed to give the clutch just enough space to back off the compressor when the AC is not working. Then when it gets cold, add the shim and you have no more AC.
Going back to step one, if the clutch engages like it should when you press the button, and you still don't have cold AC, then you could be low on freon, and have a leak. OR, the valve inside the AC exchanger could be bad. THAT is another installation how-to. But it's not kick ass hard.
Make sure your belts are in tact. And if you do get freon, get the kind that has the leak detector/UV ink as well as a pressure gauge.
