Originally Posted by Zain
how about the rear seats
how to remove them
Depends if you've got fixed rear seats or folding rear seats. Removing fixed rear seats is the easiest. You just pull up the bench seat on each side so that it unclips, remove it from the vehicle and you'll see three bolts underneath that holds in the backrest (one on each side and on in the middle). Undo those and then lift the seat upwards so that the latches slide out of their holes. The hole thing will lift out after that.
As for the folding seats, the procedure to remove the bench seat is the same, but removing the backrests is quite different. After you pop the bench seat out, you'll have to remove the side cushions. Undo the single bolt down the bottom of each one and slide it upwards. Then you can remove the backrests by undoing the bolts holding it to the center hinge, and also undo the bolts holding each backrest to the brackets on each side of the chassis. It'll all make sense once you look at it.
