Help with AC Diagnosis
Hi guys,
I have a 93 Prizm. The AC doesn't cool as well as it did last year, but the compressor engages and some cool air is still produced. The site glass looks like smoke when the AC is running. With the AC on, I measured about 25 psi on the low side and about 110 psi on the high side. With the AC off, the pressures are about 80 psi low and 110 psi (no change) on the high side. My first thought was refrigerant but someone told me it could be a bad compressor?
I read that the correct pressures should be around 30-35 psi low and 250-300 psi high with AC on, though I am not confident in the source.
Any thoughts?
Thanks.
