dashboard lights wont light up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2010, 11:37 PM   #1 (permalink)
View ericxxd's Photo Gallery
i just successfully changed my stereo today and then as it reached night time i tried turning on my dash lights but it wont light up? like my emergency hazard , defroster, wont light, also my shift gear wont light up. on my dash board only thing that lights is the e brake but my speed gauge wont light.
my car is a corolla 1994
does anybody know the problem and how i can fix it?
thank you in advancee
ericxxd is offline   Reply With Quote
Old 05-30-2010, 11:55 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Check the fuses in the cabin, one of them has no doubt blown.
Old 05-31-2010, 12:02 AM   #3 (permalink)
where is this cabin u speak of?
im sorry im not very knowledgeable with the wiring
Old 05-31-2010, 12:12 AM   #4 (permalink)
Full Throttle
The cabin is just another name for the interior of the car. There is a fusebox on the driver's side in the footwell area (to the left of the pedals). Just pop the cover off and you'll see the fuses.
The back of the fuse box cover will have a diagram of which fuses do what. The fuses that you should check in your situation are labelled 'GAUGE' (red 10 amp) and 'TAIL' (blue 15 amp) on the back of the fuse box cover. It would pay to check all of the fuses really, but these two are the most important as they'll more than likely relate to your problem.
In order to remove the fuse, get a long-nose pair of pliers, gently grip the fuse and pull it straight out. You'll easily be able to tell if the fuse is blown because the piece of metal inside will have a break in it, and you may see slight burns marks on the fuse housing. Be sure to only take one fuse out at a time so that you know where each one goes when you put it back in.
If the diagram on the back of your fuse cover is missing or worn off, I'll scan you the diagram from my Corolla owners manual.
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
ericxxd (05-31-2010)
Old 05-31-2010, 12:15 AM   #5 (permalink)
alright thanks alot man its dark right now so i will do it first thing in the morning
thank you
you really helped me alot
Old 05-31-2010, 12:26 AM   #6 (permalink)
Full Throttle
No worries at all . Let us know how you get on.
Here's a copy of the fusebox diagram inside the cabin, just in case you need it. The picture on the left is of the fusebox on the driver's side, ignore the picture on the right:
Old 05-31-2010, 04:31 AM   #7 (permalink)
AE-202 Owner
miib14's Avatar
Gameroom cash: $356141
View miib14's Photo Gallery
it will most likely be "2. TAIL 15A"
★ 1993 Toyota Corolla Saloon ★
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
185 Bhp & 142 lbft Torque
miib14 is offline   Reply With Quote
Old 05-31-2010, 08:13 PM   #8 (permalink)
so turns out my fuses arnt blown or anything i checked them all they are all good
does anyone know wat else could be the problem?
Old 05-31-2010, 08:25 PM   #9 (permalink)
Full Throttle
Hmm, did you plug the three plugs back in the rear of the centre console when you put it back on after the stereo install? There should be three in a row vertically (one for the clock, one for the hazard lights and one for the rear-screen demister). Perhaps a couple of those wires operate other things on the same circuit. It's a long shot, but worth checking. Otherwise, check the fuses in the engine bay, inside the black box just behind the battery.
Old 05-31-2010, 08:32 PM   #10 (permalink)
View Steelballz's Photo Gallery
you said this happened after you changed the radio...?
did you tap into a wire behind the dash for the radio illumintion-wire if that applies..?
actually what is said above, you hardly took out the clocks by any chance and didnt plug in on of the plugs properly?
@scott: the hazards, if not plugged in will stop the indicators working, including the stalks, ane the demister only stops that.not sure about the auto lights if they'd stop anything else from working.....
Steelballz is offline   Reply With Quote
Old 05-31-2010, 09:21 PM   #11 (permalink)
yup i even retook out my stereo and put in my old one it doesnt work... lol
i replugged those three wires that u said and also i even checked my engine bay box.
i changed them to new ones too no luck =/
Old 05-31-2010, 09:42 PM   #12 (permalink)
its alright guys ima take it to the mecahnic tomro see wats up with thiss
Old 06-01-2010, 12:08 AM   #13 (permalink)
Rip The E Brake's Avatar
Gameroom cash: $112690
View Rip The E Brake's Photo Gallery
Make sure the clock is connected.
Without it, the illumination circuit doesn't complete.
Also make sure the illumination wire is connected to where it should be on the radio harness.
Corolla Number TWO
OLD: Corolla 1- 96 4AFE, AE101 w/ 225k Miles orig. motor, 129k trans. - TOTALED.
NEW: Corolla 2- 96 4AFE, AE101 w/ 161k Miles on motor and trans.
Rip The E Brake is offline   Reply With Quote
Old 06-01-2010, 09:04 PM   #14 (permalink)
View musclecar64's Photo Gallery
Before you spend the money, Check your wiring. I just installed a head unit in my corolla a few months ago. After I did, it worked, but the instrument backlights didn't come on. It took me a while to figure out what was wrong, but it was my wiring. I wired the two orange wires together (dimmer and dimmer ground). I didn't know any better, but they should have been left alone. Finally after disconnecting them and taping them off, the lights worked again. (of course, I did have to replace a fuse and the dimmer rheostat as well, but I think I blew them on accident from trying to figure out what the problem was.) Check your wiring between the stereo harness and the car adapter harness. If you wired up the orange wires, undo them, and tape them off. See if that works.
musclecar64 is offline   Reply With Quote
Old 06-01-2010, 10:36 PM   #15 (permalink)
i took out my stereo and put in my old one now it still doesnt work
fuck my life
