corolla '97 tail lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2010, 01:23 PM   #1 (permalink)
View pedro lambertus's Photo Gallery
gen 7 corolla '97 tail lights
my tail lights are staying on even when i turned the car off. Can anybody give me a clue?
pedro lambertus is offline   Reply With Quote
Old 06-06-2010, 01:45 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3633350
to the nation! I'm moving your thread over to the Corolla forum so the people there can help you with an answer. However, I'd also suggest you use the search tool in that forum to find any past threads that already deal with your issue. Hope you find a resolution.
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
The Following User Says Thank You to TrailDust For This Useful Post:
pedro lambertus (06-06-2010)
Old 06-06-2010, 03:53 PM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
It's most likely the brake light switch, which is located on a bracket at the top of the brake pedal. The switch activates the brake lights when the pedal is depressed, and turns them off when it's not. Give it a press to make sure that it's not stuck. Then check that the rubber pedal stopper on the switch isn't missing or deteriorated. If it is, then there are various ways that you can fix it using household items (such as a bit of plastic and duct tape), but it's best to replace it with a genuine OEM part.
If the rubber pedal stopper is fine, check the clearances. The clearance between the brake pedal and the brake light switch should be 0.02 to 0.09 inches, and the clearance between the brake pedal and the firewall should be 5.46 to 5.85 inches (LHD models only).
Good luck, and welcome to the forums!
The Following User Says Thank You to Kiwi-Corolla For This Useful Post:
Old 06-06-2010, 09:37 PM   #4 (permalink)
thank you both kiwi and trail dust; you guys has been a great help!
