Corolla '96 ATF replacement
I have replaced transmission fluid on Toyota Corolla '96 which has 230500 mile on it. I did not let all the fluid get drained almost 3/4 of it then I have added 4 qrt red in an transmisssion fluid replacement article which normaly it is 3.3 qrt. Now I can hear knocking sound from transmission under neet of driver side. In the same day I had alignment adjustment and previously there was a leak close to axel but the mechanics could not detect the source this might be a transmission issue? If that's a case should I change the transmission fluid again to get rid of any metal residual or dirt?
Thanks
