power window mechanism broke - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2010, 04:27 PM   #1 (permalink)
View dieselturbo's Photo Gallery
96 corolla.put window down, heard snap. woulnt go up. pulled it up by hand. then could hear mechanism go up with switch. right rear.. could it havecome off track??? how to fix ,how does door panel come off.. thanks
dieselturbo is offline   Reply With Quote
Old 06-13-2010, 09:10 PM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
To remove the rear door panel, do the following:
1. Remove the pocket where your hand goes to shut the door. There is a screw holding it in place. It will simply lift out once the screw is undone.
2. Undo the screw holding the door handle in. Then pull the handle out slightly so that it's not sitting flush with the panel.
3. Pop up the power window switch panel with a flat head screwdriver. It's best to pop it from the front. It will lift up and allow you to disconnect the wiring harness.
4. There are two push-type clips on the side of the door panel. In order to get these out you must push the center in. Use a small screwdriver or a ball point pen to push the center in and then flick the main clip housing out with a small flat head screwdriver.
5. Once all of the screws/clips are removed, pull on the bottom of the door panel and you will hear the clips pop out.
6. The door trim will now be completely loose, so all you need to do is lift it up and take it off. Getting the door handle through the trim is the hardest part, but if you turn the handle on an angle it will go through very easily. Alternatively, just disconnect the metal arm from the door handle.
It's not as hard as it sounds and should only take you 10-minutes or so if it's your first time doing it. Personally, I think it sounds like it's time for a new electric window regulator. You may get lucky and find that it has come off track, but in most cases it's the regulator at fault. In the meantime, hold the window up with small chocks of wood.
Good luck
Old 06-16-2010, 05:25 PM   #3 (permalink)
View Steelballz's Photo Gallery
if you heard snap then I'd assume part of the regulator to be at fault...the corolla reg's have w wire for up and a wire for down connected to the reg and seperated by a bit of white plastic.....and I assume this is the crack you might've heard
JDM 7th Gen corolla parts for sale:
http://www.toyotanation.com/forum/sh...d.php?t=342712
Steelballz is offline   Reply With Quote
