97 Corolla Rear Engine Mount
It's a 7afe automatic with 160,000 miles. I've already replaced the front, front right, and transmission mount. Vibration has been reduced substantially. However, there is still some vibration, especially if stopped with transmission in drive or reverse. Previously attempted to replace the rear mount, however could not complete the job because I was pressed for time, and could not get enough clearance to extract the mount between the engine and cross member. On the next attempt, I intend to loosen the the right front mount and the transmission mount to get enough clearance when I jack up the engine so the rear mount will shimmy out. I'm wondering if anyone else has tried this approach, it seems like it should work. Any comments on the best way to go about it?
