[DIY] Making Your Own Front Strut Bar - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-24-2010, 01:05 AM   #1 (permalink)
BigDAT's Avatar
View BigDAT's Photo Gallery
gen 7 [DIY] Making Your Own Front Strut Bar
So before we begin, here is the final product:
Now, things you will need are:
Plate Steel ( I used 1/8" )
Steel tubing, square or round ( I used 1" round tube )
Thin cardboard/tagboard
Access to a grinder, welder and something to cut plate metal ( like a plasma cutter )
Optional: Paint, sandpaper
Step 1:
Using your cardboard, cut out a template to fit on your 2 inner strut tower bolts. The way i did it, was poke the 2 holes with an awl (the holes are 4.5" away from one another) then fit it on there, and shape it with a razor blade. It should look like this once its on there:
Note: play around with the shape until you like it
Step 2:
You will need to trace your template twice (the opposite tower is identical, but flipped) onto your plate metal, and cut it out. make sure you cut it outside the line a bit, so you have room to work with.
you will want to size it up, make sure it looks correct.
Step 3:
Next you need to drill your holes, since you had holes in your template, they should be marked on the metal already. I took my awl and gave the center for each hole a little tap, so that my bit would stay put.
You want to work progressively with your bits, start with a small bit and work you way up, remember small bits work best when they are spinning fast, larger ones work better a a slower rate.
you can see i used a large variety of sizes:
once your holes are drilled, they should be a bit bigger then the bolts (to allow you to set it on there when its welded, because the towers are slanted inward)
A tip to cleaning up metal shavings, is get a paper towel and wrap it around a magnet, hover over the shavings until they stick to the towel:
then simply go to the trash and trow away the paper.
Set your now drilled piece on there (remove the nuts first), remember it will not slide down yet, because the raised pat of the tower is in the way.
Do not try to force it. Do the same for the other side.
Step 4:
Next bit you will need your grinder, you can use a grinder like this one:
or if you don't have one handy, even a table grinder should work.
Grind the inner edge first until it fits around the raised part of the tower, then roughly clean up the outer edge.
do the same for the other side as well.
Step 5:
Next part is the tubing. First get your tube:
Measure the length between your mounts (mock them up on the car) and cut your tube a bit fat, you can use a hacksaw or a cutting blade for your grinder to do this. (i cut at 38.5")
if you are using round tubing, and want to pinch the edges, use a vice, it works very well:
It should end up looking like this:
Depending how far up the mount you will be welding the tube, you may need to bend the pipe, its easy to do, using 2 pieces of wood and have a friend help you. It should end up looking like this:
Now, lay it on the mounts to mock up how it will look:
Pretty simple!
Step 6:
The is the fun part, welding! So, first thing, since your tube is mocked up on there, you need to tack weld the tubing down while its still on the car:
(you may need a friend to hold the bar in place for your first side)
should look something like this:
now that you are all ready, go ahead and weld around the seams.
Don't forget to weld the underside as well (it gets the most flex):
It should look similar to this at this point:
Now, it is pretty much done, if you want to paint it...
Brush off any slag, grind out imperfections, sand well, paint as desired.
It looks good.
Bolt on to your car!
I also painted the nuts that bolt it on, but thats just me.
I hope you enjoyed the tutorial, and post pictures if you follow it!
BigDAT is offline   Reply With Quote
Old 06-24-2010, 01:18 AM   #2 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Great guide! Looks like it turned out well. I'll add this to the DIY sticky
Old 06-24-2010, 01:27 AM   #3 (permalink)
BigDAT's Avatar
Thanks, and it turned out really great, it is surprising how drastically it changes the handling of the car.
Old 06-24-2010, 06:36 AM   #4 (permalink)
AE-202 Owner
miib14's Avatar
Gameroom cash: $356141
View miib14's Photo Gallery
great write up bro
try adding on to it to get a 3 point bar (like trd)
★ 1993 Toyota Corolla Saloon ★
トヨタ 花
♥ AE-202 Owner ♥
All about N/A Power
185 Bhp & 142 lbft Torque
miib14 is offline   Reply With Quote
Old 06-24-2010, 07:25 AM   #5 (permalink)
topnotch's Avatar
Gameroom cash: $110420
View topnotch's Photo Gallery
great DIY on the strut bar bro
topnotch is offline   Reply With Quote
Old 06-24-2010, 06:56 PM   #6 (permalink)
on full afterburner
Gameroom cash: $1345097
Did you use a solid or hollow bar?
Old 06-25-2010, 02:08 AM   #7 (permalink)
BigDAT's Avatar
hollow, as shown in one of the pictures, If i used a solid bar it would be extremely heavy, and I would need to heat the metal to pinch or bend it. Plus the hollow is very structurally strong.
Old 06-25-2010, 07:05 PM   #8 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
Nice work! Came together nicely, you should make a rear one too.
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 06-25-2010, 09:58 PM   #9 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I believe the OEM GTS strut bar is also hollow as they bend pretty easy from what I've heard... it does the job.
Old 06-26-2010, 11:34 AM   #10 (permalink)
corolla96's Avatar
View corolla96's Photo Gallery
^^^ same as TRDs
K&N SRI, TRD FSB, Magnum Steel Braided Brake Hoses, Depo Black Housing Headlights Set, Clear Signal Lenses, 9006 6000K HID, LED corner lights, lic. plate lights, trunk lights, Ractive Sport Pedals, 20% tint front, 5% tint rear, Freeway TCD-0361-1 Deck, custom front grille
corolla96 is offline   Reply With Quote
Old 06-26-2010, 01:25 PM   #11 (permalink)
BigDAT's Avatar
Yep, as a big heavy bar would be useless
