low key performance mods? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-28-2010, 12:54 AM   #1 (permalink)
Gameroom cash: $151000
View demonics12's Photo Gallery
hey guys,
so far ive installed a k&n drop in, ngk wires and plugs, and deleted the resonator.
i have also used restore and synthetic oil
im trying to keep the car quiet and reliable, are there any other ways to bump up the power a bit? i was considering bumping up the timing, but im unsure how much benefit i would see from that. i am also planning on feeding the airbox via dryer hose...
the point is low key.
demonics12 is offline   Reply With Quote
Old 06-28-2010, 01:56 AM   #2 (permalink)
Official TN Toaster
iToaster's Avatar
Gameroom cash: $348295
View iToaster's Photo Gallery
Adjusting the timing would do nothing but make the car run worse, although adjusting the ignition timing can add a little power at low rpms while subtracting it from high rpms, but that's only an option if you've got the adjustable distributor. You might want to consider a performance exhaust header, as those are known to bump power a little. A cold air intake would also offer a similar boost, but most modifications to the stock intake do very little. As far as bumping the power up, that's about all you've got before you start spending a lot of money and time.
1995 Corolla DX - 7A-FE - 5 Speed - 8K1
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
RIP white Corolla
iToaster is offline   Reply With Quote
Old 06-28-2010, 02:22 AM   #3 (permalink)
Full Throttle
Kiwi-Corolla's Avatar
Gameroom cash: $953415
iTrader Score: 16 reviews
Headers, front pipe, 2" exhaust and a cold air intake set-up are good things to start with. When I installed the CAI on my Corolla I noticed a definite increase in performance, but I see you've got a K&N filter in the standard airbox so if you want to stay with that then I'd go with your idea to run ducting to the airbox. I wouldn't use dryer hose however as it is generally far too easy to rip/tear due to the material it is made from.
A better choice would be to use hard plastic piping that has metal wire twined through it. Not only is it just as flexible as the dryer hose, it's also a lot more durable. The best choice would be to use metal piping as it will provide the least turbulence and would look a lot better. I have photos of the plastic flexible induction hose on my CarDomain page if you want to see them, just click on my signature below my post.
In saying that, a cold air intake is easy to make yourself. I can give you tips if you like as I made my one out of a couple of intercooler pipes (photos also on my CarDomain page). It will give you better gains than you'll ever see from a filter located inside the factory airbox. Hydrolocking due to rain or puddles is virtually impossible unless you literally submerge the filter underwater.
There isn't a whole lot you can do to the 4A-FE and 7A-FE engines without spending some serious cash, but the small mods listed above can certainly help. If you really want to make big power, then you'd have to look at putting in a 4A-GE engine or going down the turbo route on your current engine. Good luck!
Old 06-28-2010, 12:00 PM   #4 (permalink)
View musclecar64's Photo Gallery
If it's a 5 speed, try replacing the stock shifter cable bushings with machined brass ones. Not really a "performance" upgrade, but I just did it to mine and It shifts a lot better, which will help your driving.
musclecar64 is offline   Reply With Quote
Old 06-28-2010, 01:15 PM   #5 (permalink)
i was looking at those, theyre on sale in the for sale section right?
it seemed like he didnt know what cars it would fit, so i was going to measure them :p
so they do fit?
Old 06-29-2010, 02:12 PM   #6 (permalink)
on full afterburner
Gameroom cash: $1345097
3S-GTE swap with a huge front mount intercooler painted flat black.
