I did this job last summer, replacing all the fuel lines and the rear brake lines. It is not hard, just awark because you have to work under the car and it takes a lot of time. If you can find a DIY garage where you can rent a lift, it would make things much easier.
The thing is the process of removing only one line can affect or damage the other lines because they run parallel to each other and are hold together by a series of brackets and spacers. The lines cross each other at some point. If your lines are rusted, a slight disturbance or movement can break it, such as disturbance caused by removing one line.
The 5 lines are:
1- Fuel main supply (with arrow on your pic)
2- fuel return
3- Evap canister
4- Left rear brake
5- Right rear brake
All these lines can be bought pre-bent at the dealership but that would cost more (I paid $90 each for the main fuel supply and the fuel return lines). For the brake lines, I bought generic steel lines that I bent myself. If you bent your own lines, you will need to buy a flaring tool for the hydralic connections (be careful, our cars use the double flare type, not the bubble flare so don't buy the wrong tool)
I would highly recommend to buy the 2 fuel lines pre-bent and DIY.
Having this kind of job done at a dealership will be very expensive because of the long labor involved.
Don't go cheap by cutting out the leaking section and replacing the cut out section with a short hose and clamps. It might work for a short term and you don't know for how long.
P.S. from your pic, it appears your 2 rear brake lines are not original and have been repaired at some point by the lazy method (the 2 hydraulic couplings below your green arrow on the picture) If I were you, I would replace the brake lines too.
